I can't for the life of me figure this out. I'm getting very frustrated.
When clicking the "install" button to install a .deb package, it does absolute nothing. I click it more than once, and still, nothing.
I've even tried installing the .deb file through terminal:
sudo apt install <package name>.deb
and get:
> E: Unable to locate package code_1.13.1-1497464373_amd64.deb E:
> Couldn't find any package by glob 'code_1.13.1-1497464373_amd64.deb'
> E: Couldn't find any package by regex
Someone please help before I pull my hair out.
Thank you.
Jonathon
  • 103
You are using wrong command in terminal.
You have to use sudo dpkg -i DEB_PACKAGE.
Replace DEB_PACKAGE by your packagename.deb. Your *.deb should be in $HOME folderfor the above command to work. Otherwise, use full pathname.
For details see this question.
Other Way
You can also install a deb file by double clicking it using gdebi. Install it by command sudo apt-get install gdebi and then open the *.deb file by double clicking using open with gdebi.
kashish
  • 1,342
