In windows there is "Tera-copy" for copy,cut and delete like operations. Is there is any software in ubuntu. Because I am using ubuntu11.10 the default copy manager is hanging some times and very slow.
Helps you to integrate UltraCopier on the Nautilus/Nemo file browser.
After install: Select one option
Restart your computer(recommended)
Logout and login
Execute for:
Nemo: nemo -q (save your work first)
Nautilus: nautilus -q (save your work first)
To configure your keyboard shortcut
Rigth click on the desktop and then in Configure UltraCopier.
To install on ubuntu 14.04:
For Nemo:
sudo add-apt-repository ppa:lestcape/ultracopier-extensions
sudo apt-get update
sudo apt-get install nemo-ultracopier
For Nautilus:
sudo apt-get update
sudo apt-get install nautilus-ultracopier
To remove:
sudo apt-get install ppa-purge
sudo ppa-purge ppa:lestcape/ultracopier-extension
For Nemo:
sudo apt-get purge nemo-ultracopier
For Nautilus:
sudo apt-get purge nautilus-ultracopier
Report any problem:
You could try using the cp command at the command line. It's much less likely to hang than the GNOME copy manager.
- 743
This might not exactly be gui, but pretty close to graphic user interface. I use mc (midnight commander) for cutting coping and pasting files. It works fine with ftp and ssh and provides a stable interface for a file manager if that tickles your fancy.
mc is available on ubuntu universe repository and can be installed through the command sudo apt-get install mc .
- 403
