16
When I tried to install new virtual machine in virt-manager, virtualization - localhost (QEMU) is not connected.
It shows Error: No active connection to installed on. How to fix this problem.
muru
  • 207,228
aditya
  • 161
5 Answers5
10
You are likely going to need to make sure your user owns the libvirt socket
sudo chown $USER:$USER /var/run/libvirt/libvirt-sock
Jab
  • 85
David SHainidze
  • 2,718
  • 13
  1. Verify you have all packages you need
    sudo apt install -y qemu-kvm libvirt0 libvirt-bin virt-manager bridge-utils
    sudo systemctl enable libvirt-bin
  2. Verify that libvirtd and libvirt-bin are up and running
    sudo service libvirtd status
    sudo service libvirt-bin status
  3.  sudo systemctl reboot
kurdtpage
  • 187
Zeh
  • 151
Make sure your username is part of the libvirt group. Try running sudo adduser <username> libvirt. This fixed the problem for me.
ayeiser
  • 51
In my case I had the error when trying to run it right after the installation.
I tried restarting the libvirtd service in that same session but with no success.
I tried logging out and logging back in still with no success.
But after rebooting the machine, all was fine.
Wadih M.
  • 392
Try restarting the libvirtd service:
sudo service libvirtd stop
sudo service libvirtd start
kurdtpage
  • 187
