I am trying to create a Virtual Machine using Virtual Machine Manager. I have installed the following packages using the command:
sudo apt install -y qemu qemu-kvm libvirt-daemon libvirt-clients bridge-utils virt-manager
Virtual Machine Manager is now installed but when I start it the screen says QEMU/KVM-not connected. I right clicked and then clicked on connect which gave me the following error:
Unable to connect to libvirt qemu:///system.
Verify that the 'libvirtd' daemon is running.
Libvirt URI is: qemu:///system
Traceback (most recent call last): File "/usr/share/virt-manager/virtManager/connection.py", line 956, in _do_open self._backend.open(connectauth.creds_dialog, self) File "/usr/share/virt-manager/virtinst/connection.py", line 172, in open conn = libvirt.openAuth(self._open_uri, File "/usr/lib/python3/dist-packages/libvirt.py", line 104, in openAuth if ret is None:raise libvirtError('virConnectOpenAuth() failed') libvirt.libvirtError: Failed to connect socket to '/var/run/libvirt/libvirt-sock': Permission denied
I have verfied the service libvirtd is already active(running). So what's the issue and how do i solve it?
Also I've already referred this question although it didn't help.
GAD3R
  • 3,748
Installing libvirtd and depending packages will automatically put users that are in the sudo group to also be able to use libvirt. It also sets environment variables for the shell commands.
All that won't be active for existing logons, therefore to be able to use everything you need to re-logon (or start a new terminal, ...) after installing the packages.
Christian Ehrhardt
  • 2,195
  • 16
  • 22
