I have an external USB antenna whose driver was installed, yet does not appear in System Settings/Connections in Kubuntu 17.04. More information can be found in the original question about this issue (How Can I Enable a Realtek USB Antenna?).
Output of lsmod | grep 8812 & rfkill list all
$ lsmod | grep 8812
$ rfkill list all
$: hci0: Bluetooth
        Soft blocked: no
        Hard blocked: no
Output of sudo dkms status:
bbswitch, 0.8, 4.10.0-24-generic, x86_64: installed
bbswitch, 0.8, 4.10.0-26-generic, x86_64: installed
nvidia-381, 381.22, 4.10.0-24-generic, x86_64: installed
nvidia-381, 381.22, 4.10.0-26-generic, x86_64: installed
rtl8812au, 4.3.8.12175.20140902+dfsg, 4.10.0-24-generic, x86_64: installed
rtl8812au, 4.3.8.12175.20140902+dfsg, 4.10.0-26-generic, x86_64: installed
Outpus of modinfo 8812au | grep A811:
alias:          usb:v7392pA811d*dc*dsc*dp*ic*isc*ip*in*
Output of lsmod | grep 8812:
Nothing Displayed
modprobe: ERROR: could not insert '8812au': Exec format error
Output of dmesg | grep -i -e rtl -e 8812:
[22538.388812] usb 2-14: Device not responding to setup address.
[65970.179027] 8812au: version magic '4.10.0-24-generic SMP mod_unload ' should be '4.10.0-26-generic SMP mod_unload '
Output of iwconfig & dmesg | grep 8812:
sarah@ConvergentRefuge:~$ iwconfig
eno1      no wireless extensions.
lo        no wireless extensions.
sarah@ConvergentRefuge:~$ dmesg | grep 8812
[ 2028.287249] RTL871X: rtl8812au v4.3.8_12175.20140902
[ 2028.287338] usbcore: registered new interface driver rtl8812au
[ 2033.979052] audit: type=1400 audit(1499387534.619:709): apparmor="DENIED" operation="mknod" profile="webbrowser-app" name="/dev/shm/lttng-ust-wait-7" pid=8812 comm="QQmlThread-ust" requested_mask="c" denied_mask="c" fsuid=1000 ouid=1000
[ 2623.150998] audit: type=1400 audit(1499388123.752:1185): apparmor="DENIED" operation="mknod" profile="webbrowser-app" name="/dev/shm/lttng-ust-wait-7-1000" pid=9914 comm="QQmlThread-ust" requested_mask="c" denied_mask="c" fsuid=1000 ouid=1000
[ 2623.170431] audit: type=1400 audit(1499388123.772:1186): apparmor="DENIED" operation="mknod" profile="webbrowser-app" name="/dev/shm/lttng-ust-wait-7-1000" pid=9915 comm="QQmlThread-ust" requested_mask="c" denied_mask="c" fsuid=1000 ouid=1000
[ 2623.252008] audit: type=1400 audit(1499388123.856:1187): apparmor="DENIED" operation="mknod" profile="webbrowser-app" name="/dev/shm/lttng-ust-wait-7" pid=9916 comm="QQmlThread-ust" requested_mask="c" denied_mask="c" fsuid=1000 ouid=1000
[ 2623.295266] audit: type=1400 audit(1499388123.900:1188): apparmor="DENIED" operation="mknod" profile="webbrowser-app" name="/dev/shm/lttng-ust-wait-7" pid=9917 comm="QQmlThread-ust" requested_mask="c" denied_mask="c" fsuid=1000 ouid=1000
[ 2628.207767] audit: type=1400 audit(1499388128.812:1189): apparmor="DENIED" operation="mknod" profile="webbrowser-app" name="/dev/shm/lttng-ust-wait-7-1000" pid=9918 comm="QQmlThread-ust" requested_mask="c" denied_mask="c" fsuid=1000 ouid=1000
[ 2628.252204] audit: type=1400 audit(1499388128.856:1190): apparmor="DENIED" operation="mknod" profile="webbrowser-app" name="/dev/shm/lttng-ust-wait-7-1000" pid=9919 comm="QQmlThread-ust" requested_mask="c" denied_mask="c" fsuid=1000 ouid=1000
[ 2628.302456] audit: type=1400 audit(1499388128.904:1191): apparmor="DENIED" operation="mknod" profile="webbrowser-app" name="/dev/shm/lttng-ust-wait-7" pid=9920 comm="QQmlThread-ust" requested_mask="c" denied_mask="c" fsuid=1000 ouid=1000
[ 2628.341144] audit: type=1400 audit(1499388128.944:1192): apparmor="DENIED" operation="mknod" profile="webbrowser-app" name="/dev/shm/lttng-ust-wait-7" pid=9921 comm="QQmlThread-ust" requested_mask="c" denied_mask="c" fsuid=1000 ouid=1000
Sarah Szabo
  • 1,513
  • 30
  • 59
First, verify that the module installed correctly:
sudo dkms status
We hope we see:
rtl8812AU, 5, 4.10.0-26-generic, x86_64: installed
Or similar.
Verify that the installed module covers your device, which is:
ID 0bda:a811 Realtek Semiconductor Corp.
Run, in the terminal:
We hope we see:
alias:          usb:v0BDApA811d*dc*dsc*dp*ic*isc*ip*in*
Note that the second alias, 0BDA with A811 covers your device.
Is the module loaded?
lsmod | grep 8812
If not, load it:
sudo modprobe 8812au
Are there any errors or warnings you can post? Or does the wireless come to life? If not, check the log for informative messages:
EDIT: We see the problem here:
I suggest that you correct it with:
 sudo apt-get purge rtl8812au-dkms
 sudo apt-get install rtl8812au-dkms
If there are errors or warnings, please post them.
EDIT2: I suggest that we try another approach.
sudo apt-get install git
git clone https://github.com/jeremyb31/rtl8812AU.git
sudo dkms add ./rtl8812AU
sudo dkms install rtl8812AU/5
Reboot and let us hear your report.
chili555
  • 61,330
After 8 hours of trying finally these steps worked for me:
  1. first I turned the secure boot off inside the BIOS (this step was the key solution) Because of this change I was able to run : $ modprobe 8812au Otherwise I got the permission denied response
  2. I used this repo to install the driver: aircrack-ng/rtl8812au
  1. reboot
  2. if it is necessary:
    $ modprobe 8812au
or
$ sudo modprobe 8812au
or
$ modprobe --force 8812au
or
$ sudo modprobe --force 8812au
worked for me
device: alfa awus036ach USB wireless adapter
os: ubuntu 20.04 LTS
