25
Say I recently installed unattended-upgrades via:
sudo apt-get install unattended-upgrades -y
sudo dpkg-reconfigure --priority=low unattended-upgrades -y
Does unattended-upgrades also include apt-get autoremove?
Or should I add a weekly cronjob atop the unattended-upgrades layer to make sure dependencies of deleted packages are removed as well, via crontab -e and then:
0 0 * * 0 apt-get autoremove -y
Note: Feel free to mention similar apt concepts besides autoremove if these are needed.
guntbert
  • 13,475
Whether or not unattended-upgrades will perform the cleanup (auto remove) is controlled by the Unattended-Upgrade::Remove-Unused-Dependencies setting in /etc/apt/apt.conf.d/50unattended-upgrades. Set it as follows to enable the cleanup -- and you should be able to remove the explicit autoremove cron-job:
Unattended-Upgrade::Remove-Unused-Dependencies  "true";
Kulfy
  • 18,154
11
In addition to Mikhail's suggestion, it is also useful to autoremove unused kernel packages. This will keep the /boot/ partition from filling up on some Ubuntu systems. A full /boot partition can lead to issues.
Unattended-Upgrade::Remove-Unused-Kernel-Packages "true";
Gryu
  • 8,002
  • 37
  • 53
