I have the problem described here: How to solve bleaching Krusader? and I want to reset Krusader configuration to fresh-install-like one. (unfortunately opening configuration and applying defaults does not help)
- How can I completely reset Krusader configuration to fresh-install-like one (preferably) or
- Remove Krusader config file (what's the name and where's it located?)
I tried to remove configuration files as described here: https://docs.kde.org/trunk5/en/extragear-utils/krusader/config_files.html but:
$ qtpaths --paths GenericDataLocation
qtpaths: could not find a Qt installation of ''
And no such files exist:
~/.config/krusaderrc
~/.local/share/kxmlgui5/krusader/krusaderui.rc
I do not believe that global config is screwed as this user has no access there nor this user is in sudoers list.
One important thing to mention is that when I start Krusader from terminal the following error message is printed:
$ krusader
krusader(6646)/kdecore (KLibrary) findLibraryInternal: plugins should not have a 'lib' prefix: "libkonsolepart.so"
So it looks like there is some package conflict - before I had installed some other utilities krusader had worked as expected. See the exact description in linked question (bleaching Krusader).
