I am new to Ubuntu. I have googled a lot to try and get answers and have not succeeded. This is a refurbed Thinkpad with Windows 10. I used Rufus to create a bootable usb with Ubuntu. Then I rebooted the Thinkpad, pressed F12 to choose the Usb for booting. So far so good.
But, now nothing happens. I am looking at a black screen with a blinking cursor. I've waited about 15 minutes thinking that maybe it's a very slow process. But nothing.
The computer has 4Gig of memory but otherwise its on the slow side. It has 150G of SSD.
Any tips? Thanks!
pitosalas
  • 183
Type crtl + alt + f2 -- > if you made an account login
Then sudo service lightdm restart
NerdOfCode
  • 2,608
under Rufus after u choose the ISO file, change the partition scheme to MBR with BIOS option, it should prompt you to download some file and then it will re-create the bootup disk. After that u should be able to boot up. If this solves your problem, it most probably is because your motherboard does not support UEFI (Unified Extensible Firmware Interface) which after you selected the ISO it automatically changed even you changed before selecting the ISO file. Hope it helps
Similar problem.
I've made sure that the USB stick iso is set to MBR. During boot I press F12 and get the option to load the USB stick. Then the menu appears and when choosing to try Ubuntu without installing I can see the splash screen which is then turned to a black screen which stays. forever... I've tried to edit the menu option to include nomodeset as suggested in another thread (My computer boots to a black screen, what options do I have to fix it?) but it only results in having some blurred lines on the screen. I'd appreciate any help!
Adi
Adi Lavy
  • 313
