I use KDE plasma 5.10.1 .
I use Alt+1 ... Alt+10 to change tabs in web browsers or konsole .
my problem is Alt+1 not working in plasma desktop and i always replace /usr/bin/kglobalaccel5 to /usr/bin/kglobalaccel for fix this problem .
For a long time plasma 5 have this problem .
Why kglobalaccel5 can not handle Alt+1 ?
note : I dont use NumPad
mah454
  • 169
There is a shortcut in System Setting/Shortcuts/Global Shortcuts for Walk Through Windows of Current Application (Reverse), which is set to alt+~, if you delete that shortcut (i.e. set it to custom and leave it empty, then press apply) you will be able to use alt+1 in other applications, like you case with the browser.
(Tested under different Linux distro with KDE Plasma.)
Edit: on my keyboard layout ~ is on key 1, maybe that is why it worked for me.
disabling Alt+` and Alt+~ shortcut will works but we will remove a good shortcut! the better way is to edit the "ir" keyboard layout manually and remove the accent from key 1.
Follow this steps:
  • sudo vi /usr/share/X11/xkb/symbols/ir
  • find a line containing this:
key <AE01> { [ Farsi_1,     exclam,              grave,                   1       ] };
  • remove "grave,". the new line should be:
key <AE01> { [ Farsi_1,     exclam,              1       ] };
  • save and exit
  • remove ir keyboard and add again
  • Finished!
