libreoffice: Depends: libreoffice-core (= 1:3.4.4-0ubuntu1) but 1:3.4.3-3ubuntu2 is to be installed
             Depends: libreoffice-base but it is not going to be installed
             Depends: libreoffice-report-builder-bin but it is not going to be installed
             Depends: ttf-dejavu but it is not going to be installed
             Depends: ttf-sil-gentium-basic but it is not going to be installed
             Depends: libreoffice-filter-mobiledev but it is not going to be installed
             Depends: libreoffice-java-common (>= 1:3.4.4~) but it is not going to be installed
libreoffice-base-core : Depends: libreoffice-core (= 1:3.4.4-0ubuntu1) but 1:3.4.3-3ubuntu2 is to be installed
libreoffice-calc : Depends: libreoffice-core (= 1:3.4.4-0ubuntu1) but 1:3.4.3-3ubuntu2 is to be installed
libreoffice-draw : Depends: libreoffice-core (= 1:3.4.4-0ubuntu1) but 1:3.4.3-3ubuntu2 is to be installed
libreoffice-gnome : Depends: libreoffice-core (= 1:3.4.4-0ubuntu1) but 1:3.4.3-3ubuntu2 is to be installed
libreoffice-gtk : Depends: libreoffice-core (= 1:3.4.4-0ubuntu1) but 1:3.4.3-3ubuntu2 is to be installed
libreoffice-impress : Depends: libreoffice-core (= 1:3.4.4-0ubuntu1) but 1:3.4.3-3ubuntu2 is to be installed
libreoffice-math : Depends: libreoffice-core (= 1:3.4.4-0ubuntu1) but 1:3.4.3-3ubuntu2 is to be installed
libreoffice-writer : Depends: libreoffice-core (= 1:3.4.4-0ubuntu1) but 1:3.4.3-3ubuntu2 is to be installed
python-uno : Depends: libreoffice-core (= 1:3.4.4-0ubuntu1) but 1:3.4.3-3ubuntu2 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Jorge Castro
  • 73,717
Lucky
I had the same problem. I'm essentially lazy with installations, so I just did the following:
Open a terminal and type the following:
sudo apt-get update
sudo apt-get -f install
Just type "Y" when prompted.
jokerdino
  • 41,732
Bryce
Sounds like you are mixing libreoffice from oneiric and libreoffice-core from oneiric-updates. Make sure that you have "Updates" enabled in "Software Sources".
tumbleweed
  • 8,106
