Today I upgraded my Ubuntu distro from 16.04 to 17.04. Result: the keyboard and the usb ports don't work anymore.
I upgraded the distro via command line:
sudo apt update && sudo apt dist-upgrade
sudo do-release-upgrade
It seems that I need to install a generic linux kernel.
Problem: if I run the installed version of Ubuntu I cannot install the kernel.
Can I install a kernel on my system from a live session?
Zanna
  • 72,312
I solved the issue following these steps on the Ubuntu help wiki
Update Failure
If there was an update that made your system non-bootable and they have fixed it in the repositories, you can use the Live CD to run apt-get to get the new files to fix your system.
Boot the Ubuntu Live CD. Press Ctrl-Alt-F1
sudo mount /dev/sda1 /mnt
sudo mount --bind /dev /mnt/dev
sudo mount --bind /proc /mnt/proc
sudo mount --bind /sys /mnt/sys
sudo chroot /mnt
sudo apt update
sudo apt upgrade
Then
sudo apt dist-upgrade -y && sudo apt install -y ubuntu-desktop*
I had a similar problem, upgraded from 16.04 to 17.o4 and found my keyboard no longer worked.
Found the fix here:
https://askubuntu.com/a/932041
I also had this issue after the upgrade. After reading several posts, it seems that the issue is related to a missing package.
1st Start Ubuntu in recovery mode
2nd Select the Enable Networking option in the menu
3rd Now, select the root option and enter your root password (if set)
4th Configure your DNS In the command line edit the file: /etc/resolv.conf example: pico /etc/resolv.conf or vi /etc/resolv.conf Add to the first line of the file.
nameserver 208.67.222.222
Now save the file
5th install the missing package
apt install xserver-xorg-input-all
Finally restart your machine and your are good to go!
I had this issue. Luckily I was able to re-install 16.04 LTS and re-update to 17.04 on an old test laptop (HP EliteBook 8530p).
At the end of the update when it asks to remove obsolete packages, I simply chose KEEP and my mouse and keyboard worked after reboot.
Unfortunately, this solution only works if you find this answer before you dismiss that dialog and reboot. Otherwise, other solutions are required.
Kory Gill
  • 101
