How can I install Windows after I've installed Ubuntu?
Long story short: Windows 10 was preinstalled in my ASUS ROG GL752VW-DH71. I updated my drivers using Driver Booster & Intel's own software, afterwards I can't boot anymore so I impulsively clean installed Ubuntu 16.04 LTS.
Then, I figured I need Windows 10 again for some other stuff, so I am trying to install it again.
What I've done so far:
  1. made two bootable flash drives, one with Win10 and one with Ubuntu 16.04 LTS
  2. used GParted from the Ubuntu image and resized my 250GB SSD so there would be at least 50GB for Windows 10 (unallocated space)
  3. disabled fastboot & secure boot, enabled CSM, put my HDD (P2: Samsung 850 EVO 250GB...) on the top of the boot priority, then manually booted from my flash drive (UEFI: SanDisk Cruzer...)
  4. the setup ran, it was normal until it asked me where to install Windows. I made a new partition and then afterwards the setup made 4 partitions. the drive is GPT by the way.
  5. tried installing Windows on the 50GB partition I just made but it says "We couldn’t create a new partition or locate an existing one. For more information, see the Setup log files.".
I'm totally lost, everything I could find just wants me to clean the drive & make a new partition using diskpart, but I don't want to do that, there's already a lot of stuff in my Ubuntu installation :(
However, I can most probably backup my entire Ubuntu installation, format the whole drive & install Windows 10 first, then restore Ubuntu. I just don't know how to/where to start.
Any help would be appreciated. Thanks in advance!
It turns out that my problem was caused by the leftover Windows files on my HDD that came with the laptop, I forgot that it wouldn't automatically be wiped if you just formatted it with Windows.
I also made sure that I had the following partitions on sda: - unallocated space - Windows partition (NTFS) - unallocated space
And the Windows 10 installer went smoothly. You can do this with GParted.
