Otherwise stable Ubuntu machine have an issue since installing that is critical freezing without apparent reasons. There are high probabilities that the issue been caused by NVDIA videocard.
sudo blkid output:
/dev/sda2: UUID="0E5C95E45C95C73D" TYPE="ntfs" PARTUUID="1ef0523b-02"
/dev/sda5: UUID="16EA-1372" TYPE="vfat" PARTUUID="1ef0523b-05"
/dev/sda6: UUID="fe90c52c-c1b7-4845-971e-e7ed5cb45ac4" TYPE="ext4" PARTUUID="1ef0523b-06"
/etc/fstab:
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda6 during installation
UUID=fe90c52c-c1b7-4845-971e-e7ed5cb45ac4 / ext4 errors=remount-ro 0 1
/swapfile none swap sw 0 0
/dev/mapper/cryptswap1 none swap sw 0 0
/etc/crypttab:
cryptswap1 UUID=f09a516a-22c0-475c-b749-31ffed5c7bda /dev/urandom swap,offset=1024,cipher=aes-xts-plain64
ls -alh /swapfile:
-rw------- 1 root root 2.0G May 3 13:31 /swapfile
