Issue
- I want to automate downloading a file via SFTP
- I set up an SFTP server and a keying mechanism
- I have created a simple bash script - script.sh
- I added an entry in cron for the script
The script, script.sh:
#!/bin/bash
sftp user@server:/home/user/file.txt
exit 0
Executing the script manually works fine (text file is saved in home directory), but adding script.sh (with proper permissions) to crontab does nothing.
The crontab entry:
* * * * * /home/user/script.sh
For authentication I used ssh-keygen to create a set of keys (private, public) and set up cross authentication to the SFTP server.
For script automation I used keychain for password-less authentication.
Currently
Currently, I have a script called script.sh located in the "user" home directory (/home/user/).
When run by root manually, the script gets the file from the SFTP server, and places it in /home/user/.
It does not perform this action when run from a cron job. In cron, the sftp command gets an error.
Ideas?
Working on it
- Changing the HOME variable on
/etc/crontabdid not solve the issue - Stating full paths in script.sh did not solve the issue
- Stating PATH variable in script.sh did not solve the issue
- I catched the error from the
sftpcommand - it's 255
executing the script manually (./script.sh) still works flawlessly though...
