36
A few days ago I installed Xubuntu on top of a normal Ubuntu system:
sudo apt-get install xubuntu-desktop
I didn't play around for long on Xubuntu before I realised that I liked Ubuntu 2D better. Now my problem is how do I uninstall Xubuntu and all of it's dependencies and the recommended packages like Thunar and Abiword.
For now I just run:
sudo apt-get remove xubuntu-*
but I still have a lot left from Xubuntu. It would be nice if by doing
apt-get remove xubuntu-desktop
all of the packages installed with the metapackages were also removed, but that is not the case.
BuZZ-dEE
  • 14,533
buzu
  • 363
6 Answers6
36
The following command will remove 95% of Xubuntu and XFCE -- instead of the other commands mentioned that remove only 50% ... 60% ... of the packages.
sudo apt-get autoremove --purge xubuntu-* && sudo apt-get autoremove --purge xfce*
If you're willing to be more radical... You can run the following command. This one remove almost everything about xubuntu/xfce:
sudo apt-get autoremove --purge $( dpkg-query -l *xubuntu* | grep ii | tr -s " " | cut -d" " -f2; dpkg-query -l *xfce* | grep 'ii' | tr -s " " | cut -d" " -f2 )
Bruno Pereira
  • 74,715
22
You can try this -
sudo apt-get remove abiword abiword-common abiword-plugin-grammar abiword-plugin-mathview bison blueman brltty-x11 catfish elementary-icon-theme exo-utils flex gigolo gimp gimp-data gmusicbrowser gnome-icon-theme-full gnome-system-tools gnome-time-admin gnumeric gnumeric-common gnumeric-doc gstreamer0.10-gnomevfs gthumb gthumb-data gtk2-engines-pixbuf gtk2-engines-xfce indicator-application-gtk2 indicator-messages-gtk2 indicator-sound-gtk2 indicator-status-provider-pidgin leafpad libabiword-2.8 libaiksaurus-1.2-0c2a libaiksaurus-1.2-data libaiksaurusgtk-1.2-0c2a libao-common libao4 libaudio-scrobbler-perl libbabl-0.0-0 libclutter-1.0-0 libclutter-1.0-common libclutter-gtk-1.0-0 libcogl-common libcogl5 libconfig-inifiles-perl libencode-locale-perl libept1 libexo-1-0 libexo-common libfile-listing-perl libfont-afm-perl libgarcon-1-0 libgarcon-common libgdome2-0 libgdome2-cpp-smart0c2a libgegl-0.0-0 libgimp2.0 libglade2-0 libgnomevfs2-extra libgoffice-0.8-8 libgoffice-0.8-8-common libgsf-1-114 libgsf-1-common libgstreamer-perl libgtk2-notify-perl libgtk2-trayicon-perl libgtkmathview0c2a libhtml-form-perl libhtml-format-perl libhtml-parser-perl libhtml-tagset-perl libhtml-tree-perl libhttp-cookies-perl libhttp-daemon-perl libhttp-date-perl libhttp-message-perl libhttp-negotiate-perl libid3tag0 libido-0.1-0 libilmbase6 libio-socket-ssl-perl libjpeg-progs libkeybinder0 liblink-grammar4 libloudmouth1-0 liblwp-mediatypes-perl liblwp-protocol-https-perl libmad0 libmailtools-perl libnet-dbus-perl libnet-http-perl libnet-ssleay-perl liboobs-1-5 libopenexr6 libotr2 libots0 libpolkit-gtk-1-0 libsexy2 libtagc0 libthunarx-2-0 libtie-ixhash-perl libtimedate-perl libtumbler-1-0 liburi-perl libwv-1.2-3 libwww-perl libwww-robotrules-perl libxfce4ui-1-0 libxfce4util-bin libxfce4util-common libxfce4util4 libxfcegui4-4 libxfconf-0-2 libxml-parser-perl libxml-twig-perl libxml-xpath-perl libxss1 lightdm-gtk-greeter link-grammar-dictionaries-en m4 mpg321 murrine-themes orage parole pastebinit pidgin pidgin-data pidgin-libnotify pidgin-microblog pidgin-otr plymouth-theme-xubuntu-logo plymouth-theme-xubuntu-text python-configobj python-glade2 quadrapassel ristretto screensaver-default-images synaptic system-tools-backends tango-icon-theme tango-icon-theme-common tcl8.5 thunar thunar-archive-plugin thunar-data thunar-media-tags-plugin thunar-volman ttf-droid ttf-lyx tumbler tumbler-common xchat xchat-common xfburn xfce-keyboard-shortcuts xfce4-appfinder xfce4-cpugraph-plugin xfce4-dict xfce4-fsguard-plugin xfce4-indicator-plugin xfce4-mailwatch-plugin xfce4-mixer xfce4-mount-plugin xfce4-netload-plugin xfce4-notes xfce4-notes-plugin xfce4-notifyd xfce4-panel xfce4-places-plugin xfce4-power-manager xfce4-power-manager-data xfce4-quicklauncher-plugin xfce4-screenshooter xfce4-session xfce4-settings xfce4-smartbookmark-plugin xfce4-systemload-plugin xfce4-taskmanager xfce4-terminal xfce4-utils xfce4-verve-plugin xfce4-volumed xfce4-weather-plugin xfconf xfdesktop4 xfdesktop4-data xfwm4 xfwm4-themes xscreensaver xscreensaver-data xscreensaver-gl xubuntu-artwork xubuntu-default-settings xubuntu-desktop xubuntu-docs xubuntu-icon-theme xubuntu-wallpapers && sudo apt-get install ubuntu-desktop
Source: http://www.psychocats.net/ubuntu/puregnome
Update: on (X)Ubuntu 13.10 the code above might yield an error on packages libabiword-2.8 and ttf-droid, so you might actually have to run this:
sudo apt-get remove abiword abiword-common abiword-plugin-grammar abiword-plugin-mathview alacarte bison blueman brltty-x11 catfish espeak exo-utils flex fonts-droid fonts-lyx gigolo gmusicbrowser gnome-system-tools gnome-time-admin gstreamer0.10-gnomevfs gthumb gthumb-data gtk2-engines-pixbuf indicator-application-gtk2 indicator-sound-gtk2 leafpad libabiword-3.0 libbison-dev libdigest-crc-perl libexo-1-0 libexo-common libexo-helpers libfl-dev libgarcon-1-0 libgarcon-common libgdome2-0 libgdome2-cpp-smart0c2a libglade2-0 libgnomevfs2-0 libgnomevfs2-common libgnomevfs2-extra libgsf-1-114 libgsf-1-common libgstreamer-perl libgtk2-notify-perl libgtk2-trayicon-perl libgtkmathview0c2a libgtkspell0 libido-0.1-0 libindicate-gtk3 libintl-perl libjpeg-progs libjpeg-turbo-progs libkeybinder0 liblink-grammar4 libloudmouth1-0 libnet-dbus-perl liboobs-1-5 libotr2 libots0 librarian0 libsexy2 libtagc0 libthunarx-2-0 libtidy-0.99-0 libtie-ixhash-perl libtumbler-1-0 libunique-1.0-0 libvte-common libvte9 libwv-1.2-4 libxfce4ui-1-0 libxfce4ui-utils libxfce4util-bin libxfce4util-common libxfce4util6 libxfcegui4-4 libxfconf-0-2 libxml-parser-perl libxml-twig-perl libxml-xpath-perl lightdm-gtk-greeter link-grammar-dictionaries-en m4 orage parole pastebinit pavucontrol pidgin pidgin-data pidgin-libnotify pidgin-microblog pidgin-otr plymouth-theme-xubuntu-logo plymouth-theme-xubuntu-text python-configobj rarian-compat ristretto screensaver-default-images scrollkeeper shimmer-themes system-tools-backends tcl8.5 thunar thunar-archive-plugin thunar-data thunar-media-tags-plugin thunar-volman tumbler tumbler-common xbrlapi xchat xchat-common xfburn xfce-keyboard-shortcuts xfce4-appfinder xfce4-cpugraph-plugin xfce4-dict xfce4-indicator-plugin xfce4-mailwatch-plugin xfce4-netload-plugin xfce4-notes xfce4-notes-plugin xfce4-notifyd xfce4-panel xfce4-places-plugin xfce4-power-manager xfce4-power-manager-data xfce4-quicklauncher-plugin xfce4-screenshooter xfce4-session xfce4-settings xfce4-systemload-plugin xfce4-taskmanager xfce4-terminal xfce4-verve-plugin xfce4-volumed xfce4-weather-plugin xfce4-xkb-plugin xfconf xfdesktop4 xfdesktop4-data xfwm4 xscreensaver xscreensaver-data xscreensaver-gl xubuntu-artwork xubuntu-default-settings xubuntu-desktop xubuntu-docs xubuntu-icon-theme xubuntu-wallpapers && sudo apt-get install ubuntu-desktop
Which is the same as the first code, but with libabiword-3.0 instead of 2.8 and without ttf-droid.
ManyRoads
  • 421
Review the list of packages to remove:
$ apt-cache depends xubuntu-desktop | awk '/^\s+Depends: /{print $2;}' | column
alsa-base                       inputattach                     software-properties-gtk         xfce4-notifyd
alsa-utils                      language-selector-gnome         thunar                          xfce4-panel
anacron                         libasound2-plugins              thunar-volman                   xfce4-session
bc                              libpam-systemd                  tumbler                         xfce4-settings
ca-certificates                 libsasl2-modules                ubuntu-drivers-common           xfdesktop4
dmz-cursor-theme                libxp6                          ubuntu-extras-keyring           xfwm4
doc-base                        lightdm                         unzip                           xkb-data
fonts-dejavu-core               lightdm-gtk-greeter             update-manager                  xorg
fonts-freefont-ttf              memtest86+                      wireless-tools                  xterm
foomatic-db-compressed-ppds     openprinting-ppds               wpasupplicant                   xubuntu-artwork
genisoimage                     pm-utils                        xdg-user-dirs                   xubuntu-default-settings
ghostscript-x                   printer-driver-pnm2ppa          xdg-user-dirs-gtk               zenity
gtk2-engines-pixbuf             rfkill                          xfce4-appfinder                 zip
Then either write the above to a file and edit, or just uninstall them all and then reinstall the ones you need for Ubuntu:
apt-cache depends xubuntu-desktop \
    | awk '/^\s+Depends: /{print $2;}' \
    | sudo xargs apt-get purge -y`
hobs
  • 562
To completely remove xubuntu-desktop, type the following three commands in the terminal.
sudo apt remove xubuntu-desktop
sudo apt autoremove xubuntu-desktop
sudo apt purge xubuntu-desktop
This will get rid of xubuntu-desktop, all xubuntu configuration files, and all xfce apps.
This one works For Ubuntu 12.04 Copy all this in Terminal
sudo apt-get remove abiword abiword-common abiword-plugin-grammar abiword-plugin-mathview alacarte bison blueman brltty-x11 catfish docbook-xml exo-utils flex fonts-droid gigolo gimp gimp-data gmusicbrowser gnome-desktop-data gnome-system-tools gnome-time-admin gnumeric gnumeric-common gnumeric-doc gstreamer0.10-gnomevfs gthumb gthumb-data gtk2-engines-pixbuf indicator-application-gtk2 indicator-messages-gtk2 indicator-sound-gtk2 indicator-status-provider-pidgin leafpad libabiword-2.9 libao-common libao4 libaudio-scrobbler-perl libbabl-0.0-0 libbison-dev libcolamd2.7.1 libconfig-inifiles-perl libdigest-crc-perl libencode-locale-perl libept1.4.12 libexo-1-0 libexo-common libexo-helpers libfile-listing-perl libfl-dev libfont-afm-perl libgarcon-1-0 libgarcon-common libgdome2-0 libgdome2-cpp-smart0c2a libgegl-0.0-0 libgimp2.0 libglade2-0 libgnomevfs2-0 libgnomevfs2-common libgnomevfs2-extra libgoffice-0.8-8 libgoffice-0.8-8-common libgsf-1-114 libgsf-1-common libgstreamer-perl libgtk2-notify-perl libgtk2-trayicon-perl libgtkmathview0c2a libgtkspell0 libhtml-form-perl libhtml-format-perl libhtml-parser-perl libhtml-tagset-perl libhtml-tree-perl libhttp-cookies-perl libhttp-daemon-perl libhttp-date-perl libhttp-message-perl libhttp-negotiate-perl libid3tag0 libido-0.1-0 libilmbase6 libio-socket-inet6-perl libio-socket-ssl-perl libjavascriptcoregtk-1.0-0 libjpeg-progs libjpeg-turbo-progs libkeybinder0 liblaunchpad-integration1 liblink-grammar4 libloudmouth1-0 liblwp-mediatypes-perl liblwp-protocol-https-perl libmad0 libmailtools-perl libnet-dbus-perl libnet-http-perl libnet-ssleay-perl liboobs-1-5 libopenexr6 libotr2 libots0 librarian0 libsexy2 libsocket6-perl libtagc0 libthunarx-2-0 libtidy-0.99-0 libtie-ixhash-perl libtimedate-perl libtumbler-1-0 libunique-1.0-0 liburi-perl libvte-common libvte9 libwebkitgtk-1.0-0 libwebkitgtk-1.0-common libwv-1.2-4 libwww-perl libwww-robotrules-perl libxfce4ui-1-0 libxfce4util-bin libxfce4util-common libxfce4util4 libxfcegui4-4 libxfconf-0-2 libxml-parser-perl libxml-twig-perl libxml-xpath-perl libxss1 lightdm-gtk-greeter link-grammar-dictionaries-en linux-headers-3.2.0-24 linux-headers-3.2.0-24-generic linux-headers-generic lp-solve m4 mpg321 orage parole pastebinit pavucontrol pidgin pidgin-data pidgin-libnotify pidgin-microblog pidgin-otr plymouth-theme-xubuntu-logo plymouth-theme-xubuntu-text python-configobj python-glade2 python-gmenu rarian-compat ristretto screensaver-default-images sgml-data shimmer-themes synaptic system-tools-backends tcl8.5 thunar thunar-archive-plugin thunar-data thunar-media-tags-plugin thunar-volman ttf-droid ttf-lyx tumbler tumbler-common xchat xchat-common xfburn xfce-keyboard-shortcuts xfce4-appfinder xfce4-cpugraph-plugin xfce4-datetime-plugin xfce4-dict xfce4-indicator-plugin xfce4-mailwatch-plugin xfce4-netload-plugin xfce4-notes xfce4-notes-plugin xfce4-notifyd xfce4-panel xfce4-places-plugin xfce4-power-manager xfce4-power-manager-data xfce4-quicklauncher-plugin xfce4-screenshooter xfce4-session xfce4-settings xfce4-systemload-plugin xfce4-taskmanager xfce4-terminal xfce4-utils xfce4-verve-plugin xfce4-volumed xfce4-weather-plugin xfce4-xkb-plugin xfconf xfdesktop4 xfdesktop4-data xfwm4 xscreensaver xscreensaver-data xscreensaver-gl xubuntu-artwork xubuntu-default-settings xubuntu-desktop xubuntu-docs xubuntu-icon-theme xubuntu-wallpapers && sudo apt-get install ubuntu-desktop && sudo /usr/lib/lightdm/lightdm-set-defaults -g unity-greeter
kiri
  • 28,986
T5R
The commands need to be updated to the following for Ubuntu 14.04 as libotr2 is not a valid package. It needs to be changed to libotr5. Here is the updated code. It'll reinstall ubuntu-desktop.
sudo apt-get remove abiword abiword-common abiword-plugin-grammar abiword-plugin-mathview alacarte bison blueman brltty-x11 catfish espeak exo-utils flex fonts-droid fonts-lyx gigolo gmusicbrowser gnome-system-tools gnome-time-admin gstreamer0.10-gnomevfs gthumb gthumb-data gtk2-engines-pixbuf indicator-application-gtk2 indicator-sound-gtk2 leafpad libabiword-3.0 libbison-dev libdigest-crc-perl libexo-1-0 libexo-common libexo-helpers libfl-dev libgarcon-1-0 libgarcon-common libgdome2-0 libgdome2-cpp-smart0c2a libglade2-0 libgnomevfs2-0 libgnomevfs2-common libgnomevfs2-extra libgsf-1-114 libgsf-1-common libgstreamer-perl libgtk2-notify-perl libgtk2-trayicon-perl libgtkmathview0c2a libgtkspell0 libido-0.1-0 libindicate-gtk3 libintl-perl libjpeg-progs libjpeg-turbo-progs libkeybinder0 liblink-grammar4 libloudmouth1-0 libnet-dbus-perl liboobs-1-5 libotr5 libots0 librarian0 libsexy2 libtagc0 libthunarx-2-0 libtidy-0.99-0 libtie-ixhash-perl libtumbler-1-0 libunique-1.0-0 libvte-common libvte9 libwv-1.2-4 libxfce4ui-1-0 libxfce4ui-utils libxfce4util-bin libxfce4util-common libxfce4util6 libxfcegui4-4 libxfconf-0-2 libxml-parser-perl libxml-twig-perl libxml-xpath-perl lightdm-gtk-greeter link-grammar-dictionaries-en m4 orage parole pastebinit pavucontrol pidgin pidgin-data pidgin-libnotify pidgin-microblog pidgin-otr plymouth-theme-xubuntu-logo plymouth-theme-xubuntu-text python-configobj rarian-compat ristretto screensaver-default-images scrollkeeper shimmer-themes system-tools-backends tcl8.5 thunar thunar-archive-plugin thunar-data thunar-media-tags-plugin thunar-volman tumbler tumbler-common xbrlapi xchat xchat-common xfburn xfce-keyboard-shortcuts xfce4-appfinder xfce4-cpugraph-plugin xfce4-dict xfce4-indicator-plugin xfce4-mailwatch-plugin xfce4-netload-plugin xfce4-notes xfce4-notes-plugin xfce4-notifyd xfce4-panel xfce4-places-plugin xfce4-power-manager xfce4-power-manager-data xfce4-quicklauncher-plugin xfce4-screenshooter xfce4-session xfce4-settings xfce4-systemload-plugin xfce4-taskmanager xfce4-terminal xfce4-verve-plugin xfce4-volumed xfce4-weather-plugin xfce4-xkb-plugin xfconf xfdesktop4 xfdesktop4-data xfwm4 xscreensaver xscreensaver-data xscreensaver-gl xubuntu-artwork xubuntu-default-settings xubuntu-desktop xubuntu-docs xubuntu-icon-theme xubuntu-wallpapers && sudo apt-get install ubuntu-desktop
