I just created an ntfs partition for Windows 7 dual booting. I tried deleting a few files from a folder in the windows drive, but I get the error Unable to find or create trash directory. I can create files and folders just fine, and I can delete from the command line with rm. I just can't delete with my context menu or with the del key. Why isn't is letting me and how can I fix it?
            Asked
            Active
            Viewed 3,164 times
        Alex
- 163
        This is a bug
https://bugs.launchpad.net/ubuntu/+source/glib2.0/+bug/192629
There is no solution as of yet, the work around is to add an entry in /etc/fstab
You can do this with ntfs-config, a graphical tool, or the command line.
ntfs-config
sudo apt-get install ntfs-config
gksu ntfs-config
You then change the ownership and prmissions of the ntfs partition.
command line
Edit /etc/fstab
# command line
sudo -e /etc/fstab
# graphical
gksu gedit /etc/fstab
Add a line for your ntfs partition. If you use the permissions option you can then set permissions on ntfs partitions.
/dev/sdxy /media/your_mount_point ntfs-3g user,locale=en_US.utf8,permissions 0 0
For additional information on mount options see
https://help.ubuntu.com/community/MountingWindowsPartitions
Once you have the correct permissions,
cd /media/your_mount_point
mkdir .Trash-1000
Change ".Trash-1000" you your UID (first user is 1000, use the command id to show yours)
id
        Panther
- 104,528
