i have kubuntu today after updating the muon package manager stuck at 64% so i closes it. and after that when i try to update or reinstall or install software the manger stuck. so how can i reinstall the muon package manger from terminal??
i try
sudo apt-get install muon
and i get this messege
Reading package lists... Done
Building dependency tree
muon is already the newest version.
You might want to run 'apt-get -f install' to correct these:
 libopencv-dev : Depends: libopencv-core-dev (= 2.3.1-4ppa1) but it is not going to be installed
                 Depends: libopencv-ml-dev (= 2.3.1-4ppa1) but it is not going to be installed
                 Depends: libopencv-imgproc-dev (= 2.3.1-4ppa1) but it is not going to be installed
                 Depends: libopencv-video-dev (= 2.3.1-4ppa1) but it is not going to be installed
                 Depends: libopencv-objdetect-dev (= 2.3.1-4ppa1) but it is not going to be installed
                 Depends: libopencv-gpu-dev (= 2.3.1-4ppa1) but it is not going to be installed
                 Depends: libopencv-highgui-dev (= 2.3.1-4ppa1) but it is not going to be installed
                 Depends: libopencv-calib3d-dev (= 2.3.1-4ppa1) but it is not going to be installed
                 Depends: libopencv-flann-dev (= 2.3.1-4ppa1) but it is not going to be installed
                 Depends: libopencv-features2d-dev (= 2.3.1-4ppa1) but it is not going to be installed
                 Depends: libopencv-legacy-dev (= 2.3.1-4ppa1) but it is not going to be installed
                 Depends: libopencv-contrib-dev (= 2.3.1-4ppa1) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
so what to do, i need to reinstall it because it not working
~$ sudo dpkg --configure -a
dpkg: dependency problems prevent configuration of libopencv-dev:
 libopencv-dev depends on libopencv-core-dev (= 2.3.1-4ppa1); however:
  Package libopencv-core-dev is not installed.
 libopencv-dev depends on libopencv-ml-dev (= 2.3.1-4ppa1); however:
  Package libopencv-ml-dev is not installed.
 libopencv-dev depends on libopencv-imgproc-dev (= 2.3.1-4ppa1); however:
  Package libopencv-imgproc-dev is not installed.
 libopencv-dev depends on libopencv-video-dev (= 2.3.1-4ppa1); however:
  Package libopencv-video-dev is not installed.
 libopencv-dev depends on libopencv-objdetect-dev (= 2.3.1-4ppa1); however:
  Package libopencv-objdetect-dev is not installed.
 libopencv-dev depends on libopencv-gpu-dev (= 2.3.1-4ppa1); however:
  Package libopencv-gpu-dev is not installed.
 libopencv-dev depends on libopencv-highgui-dev (= 2.3.1-4ppa1); however:
  Package libopencv-highgui-dev is not installed.
 libopencv-dev depends on libopencv-calib3d-dev (= 2.3.1-4ppa1); however:
  Package libopencv-calib3d-dev is not installed.
 libopencv-dev depends on libopencv-flann-dev (= 2.3.1-4ppa1); however:
  Package libopencv-flann-dev is not installed.
 libopencv-dev depends on libopencv-features2d-dev (= 2.3.1-4ppa1); however:
  Package libopencv-features2d-dev is not installed.
 libopencv-dev depends on libopencv-legacy-dev (= 2.3.1-4ppa1); however:
  Package libopencv-legacy-dev is not installed.
 libopencv-dev depends on libopencv-contrib-dev (= 2.3.1-4ppa1); however:
  Package libopencv-contrib-dev is not installed.
dpkg: error processing libopencv-dev (--configure):
 dependency problems - leaving unconfigured
 libopencv-dev
sudo apt-get install -f
and still same problem... and i think getting this problem because of updating kubuntu today
aseed
  • 103
I had this too... the thing that got it working for me was to reinstall muon:
sudo apt-get purge muon
Yi Jiang
  • 1,206
I had this problem too.
Try to run these commands in the terminal ("Konsole"):
c0de
  • 1,800
I had and have this problem on brand new installs. To fix I added a newer version of Muon which is considered experimental. Please remember there are risks using unfamiliar PPA,s so read this if you have any questions. The PPA I used is ppa:echidnaman/qapt form here and this is where I got the information to use this fix.
lqlarry
  • 746
Well, just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command below.
sudo apt-get -f install.
Mitch
  • 109,787
