I have a Dell XPS 13 9350 and Ubuntu 16.04. My laptop is now shutting down instead of suspending. It'll occasionally suspend properly, but I haven't found the pattern behind this. Please help... this issue wrecks my work flow.
Asked
Active
Viewed 4,997 times
I had the same issue with my Dell latitude e7270 and Ubuntu 16.04 LTS. My problem was solved when updating my kernel following the instructions here
This probably means it is an Ubuntu issue and I guess updating your kernel might do the job.
Kyriakos
- 111
You can try this:
Edit the file
/etc/default/grub(as root)Change the line with:
GRUB_CMDLINE_LINUX=""to:
GRUB_CMDLINE_LINUX="acpi_sleep=nonvs"run
update-grub(as root)
Above taken from Suspend fails (reboot on resume) and no hibernate option [closed] The answer is from 2011 and GRUB_CMDLINE_LINUX may not work the same in which case modify the GRUB_CMDLINE_LINUX_DEFAULT line instead.
These other unanswered questions are similar to yours:
WinEunuuchs2Unix
- 105,762
