I recently dual-booted my dell inspiron 15 laptop. Everything worked perfectly (both OS Windows 10 & Ubuntu 16.04). However my machine froze due to flash video during an Ubuntu update. Now my grub menu still appears, however when I want to boot into Ubuntu, all I get is a blank purple screen. I used the Ubuntu LiveDVD to install and run Boot-Repair, but that did not fix the problem. I would appreciate any pointers on how to fix this, as it is likely to happen again in the future. Thanks...
UPDATE: At the grub OS selection screen, I went to "advanced boot options for ubuntu". From there I selected the earliest available kernel for my machine along with (recovery mode). At this point, I ran the "dpkg" option, then later I also checked the file system. Currently, I can successfully boot into normal ubuntu using my earliest kernel ( "ubuntu, with Linux 4.8.0-51-generic ), however anytime I try to boot into ubuntu normally using the latest kernel ( "Ubuntu, with Linux 4.8.0-52-generic" ), I still see nothing but a purple screen. Any recommendations?
NOTE: Loading ubuntu with the latest kernel and recovery mode doesn't work. I see:
BusyBox v1.22.1 (Ubuntu 1:1.22.0-15ubuntu1) built-in shell (ash) Enter 'help' for a list of built-in commands. (initramfs) .... This last part never completes, it just keeps repeating various things about the hardware...
nightwatch
  • 805
  • 23
  • 51
The trick to solve the problem was to simply boot into my earlier kernel, then use the terminal to Reinstall the Latest Kernel. Now everything is running smoothely again
nightwatch
  • 805
  • 23
  • 51
