Every time I SSH into my AWS, I am changing editor to nano. Is there a command to run that will change it to nano for all future instances a well?
Vantage
  • 81
A couple of easy steps should see you through:
  1. Log into your account using ssh
  2. Open the file ~/.bashrcwith a text editor
  3. Add something like the following:
    export EDITOR='/usr/bin/nano'
  4. Save the file (and adjust the path to nano if you have it in a non-standard location)
  5. Either log out and back in again or simply type:
    source ~/.bashrc
And then you should be set :).
References:
andrew.46
  • 39,359
10
To set the default editor using the update-alternatives command. Open up a terminal window and type in the following command:
sudo update-alternatives --config editor
Here’s an example of what you’ll see:
$ sudo update-alternatives –config editor
There are 5 alternatives which provide `editor’.
Selection Alternative
1 /usr/bin/vim
2 /bin/ed
*+ 3 /bin/nano
4 /usr/bin/vim.basic
5 /usr/bin/vim.tiny
Press enter to keep the default[*], or type selection number:
You can select the editor you want by just typing in the number. For example, if I want to change the default editor to vim, I would just hit the number 1.
2707974
  • 10,758
