When I right click the Filezilla icon, the only options are "launch" and "properties". How do I remove it from the top panel?
You are using the Gnome-Classic interface - either you are using this by choice, or you are using the fallback mode which occurs if your graphics card & driver doesnt the 3D Acceleration required for the full Gnome-Shell GUI.
To add and remove application launchers in the gnome-panel you need to:
Press Win+Alt and right-click the top menu bar - N.B. Win is the Windows Symbol key
If you are not using Compiz then you need to :
Press Alt and right-click the top menu bar
Much more information is described in the linked Q&A and other links in that answer.
Linked Question:
Hold Alt while right-mouse clicking on the said icon.
A menu should then appear giving you the options to either move it or remove from panel.
Try
Worked on Ubuntu 16.04
gsettings set org.gnome.gnome-panel.lockdown locked-down false
