I'm using lockscreen that came with Ubuntu Gnome. It's called GDM. can I replace it with LightDM or lockscreen that comes with KDE , LXDE or others?
what are the names of these packages? how to install them?
If that's too broad then
  • How can I just install LightDM without affecting my Ubuntu Gnome Installation?
  • How can I uninstall it and get GDM back if I don't like the experience?
To install an alternate login manager use software manager or the command line
sudo apt-get install kdm
You can try slim or lightdm, both probably lighter then kdm, or try them all.
To remove them
sudo apt-get purge kdm
or slim or lightdm
To select which one to use use sudo dpkg-reconfigure gdm or edit /etc/sysconfig/displaymanager
you will get a screen where you can select which display manager (login screen) to use.
Use you up/down arrow keys to select and hit enter key.
or
sudo nano /etc/sysconfig/displaymanager
and change to the dm you wish, such as
DISPLAYMANAGER=”kdm”
sudo dpkg-reconfigure gdm has the advantage of less typing and less typographical errors.
Locking the screen when you are inactive is a different issue and is a property of the screensaver you use. By default it is gnome-screensaver but xscreensaver is probably the most popular alternate.
To configure and change screensaevers see Configure screensaver in Ubuntu
Panther
  • 104,528
