46
There are many derivatives to Ubuntu, of which Xubuntu is one, using XFCE as a desktop environment. One can install Xubuntu directly from an ISO or install XFCE as an alternative session on Ubuntu.
I am wondering: Is there more difference between installing Xubuntu from ISO and installing XFCE to Ubuntu? - If so which are these difference? - Which of the two do you recommend and why?
neydroydrec
  • 4,780
There is an Xubuntu live (desktop) CD available here at xubuntu.org/getxubuntu/.
Xfce is a desktop environment , see www,xfce.org and www.xwinman.org.
So when you install xfce you get xfce.
Xubuntu, however, is an additional set of packages and customizations to make the xfce experience more rich. xubuntu-desktop is a meta package and you can see the entire list of packages here:
www.ubuntu.com/about/about-ubuntu/derivatives
As you can see the list includes xfce + a number of additional packages.
See also help.ubuntu.com/community/Installation/LowMemorySystems#XFCE
Use which ever you prefer, from your post I would suggest you stay with Ubuntu (Unity).
Panther
  • 104,528
18
Installing XFCE will give you the upstream XFCE desktop environment. The same way that Ubuntu differs from upstream Gnome, Lubuntu differs from upstream LXDE. For instance, Ubuntu uses Firefox instead of Epiphany and Thunderbird instead of Evolution. Installing XFCE or Gnome in Ubuntu will pull in extra applications that are normally used in those environments but isn't installed by default in Ubuntu. Other than that, the software is the same so there's no radical difference.
Xubuntu has Xfce with additional packages and default configurations that differ from Xfce's. You can see the difference by choosing the Xfce session instead of the Xubuntu session, at the login manager screen.
Most likely, you want Xubuntu/xubuntu-desktop; it would be an edge case if you specifically needed Xfce and not xubuntu-desktop.
ignis
  • 4,247
