I have a feeling it's not. I'm running Ubuntu 11.10 on a Toshiba Satellite L305-S5944 Laptop. Says I have 1.8 GiB of Ram (thought I had 2). When I look at the Resources tab in the System Monitor the Swap always says 0 bytes of 0 bytes. I tried reinstalling Ubuntu 11.10, but still says the same. Both times I choose the encrypt home directory option during install. Some times when I'm booting it says some thing like "could not mount cryptswap". Tried to get a screen shot but now it's not doing it. When I look at my hard disk in the Disk Utility it shows 3 partitions created during install: 248 GB ext 4, Extended 2.0 GB, and Unknown 2.0 GB. As you can see on the screen shots the partition called Unknown, has the Partition Type: Linux swap (0x82). Sorry wouldn't let me post images.
Been having problems with crashes and slow downs pretty regularly. Also I don't see a hibernate option when I click on the button in the upper right corner. So does it look like my swap space is not functioning properly?
It's my understanding that the swap space is encrypted. Is this why it's not registering in the System Monitor or is that indicating a problem?
Is there any way to test if the swap is functioning?
If it's not working, how would I make it work, looks like it's there already, just not working possibly?
The output of "free -m" is:
total used free shared buffers cached
Mem: 1883 1729 154 0 21 634
-/+ buffers/cache: 1073 810
Swap: 0 0 0
Not sure whether it's LUKS or ecryptfs. All I did was click the check mark box that says "encrypt my home directory" or something similar during the normal installation process. I think it's ecryptfs cause I just checked the hidden files in my home folder and there's a hidden folder called ".ecryptfs"
ran blkid and the output was:
/dev/sda1: UUID="92a6b5e8-695f-4d54-a389-d5dd7c7b862e" TYPE="ext4"
/dev/sdc1: LABEL="FreeAgent GoFlex Drive" UUID="04684AE3684AD2DA" TYPE="ntfs"
sdc1 is my external HD. Also tried GParted and in addition to the sda1 it shows a sda 2 with a File System: "extended" and Size 1.87 GiB. It also shows a parition, sda5, nested inside sda2, with a File System "unknown" and size 1.87 GiB. Though next to the sda5 there is a red cirle with a "!" inside.
When I right on it and select "information" it says Status: Not mounted and at the bottom Warning: Unable to detect file system! Possible reasons are: -The file system is damaged -The file system is unknown to GParted -There is no file system available (unformatted) -The device entry /dev/sda5 is missing. Did I do something wrong during the install? I thought when I choose erase and use the whole hard drive that Ubuntu would create the swap automatically. Looks like it's there there but not working for some reason.
My /etc/fstab file looks like this:
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
proc /proc proc nodev,noexec,nosuid 0 0
# / was on /dev/sdb1 during installation
UUID=92a6b5e8-695f-4d54-a389-d5dd7c7b862e / ext4 errors=remount-ro 0 1
# swap was on /dev/sdb5 during installation
#UUID=088145ec-4c28-43e4-b3de-9f6971b08704 none swap sw 0 0
/dev/mapper/cryptswap1 none swap sw 0 0
The output of sudo fdisk -l is:
Disk /dev/sda: 250.1 GB, 250059350016 bytes
255 heads, 63 sectors/track, 30401 cylinders, total 488397168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x0001d8e9
Device Boot Start End Blocks Id System
/dev/sda1 * 2048 484472831 242235392 83 Linux
/dev/sda2 484474878 488396799 1960961 5 Extended
/dev/sda5 484474880 488396799 1960960 82 Linux swap / Solaris
Disk /dev/sdc: 640.1 GB, 640135028224 bytes
1 heads, 63 sectors/track, 19845455 cylinders, total 1250263727 sectors
Disk identifier: 0x2bc1313e
/dev/sdc1 63 1250258687 625129312+ 7 HPFS/NTFS/exFAT
I noticed that my swap in the fstab was commented out so I deleted the # to uncomment and restarted though still not working.
