32
I've installed mongodb v3.4. This starts up on boot.
So I'm wondering, how to I find out what is starting this up (and how to disable it from starting on boot)?
The following did not work:
How can I stop mongodb from starting on system boot (old)
Command to list services that start on startup? (old)
Ravexina
  • 57,256
As far as I now, services are automatically enabled in Ubuntu, so when you install something like Apache it will be started at boot.
Find some information
To find out all services that have been run at startup:
systemctl list-units --type service
this will show all services that has been loaded at boot and are active now. If you want to get a list of all services no matter they are active or not:
systemctl list-units --type service --all
Another thing you can do is to run:
systemctl list-dependencies --type service
then hit / and search for mongodb see what service/target depends on it and runs it.
Also you can run :
locate mongodb.service
Which produces something like:
/lib/systemd/system/multi-user.target.wants/mongodb.service
then you will know that it's being started as a part of multi-user target, alternative to this is:
$ systemctl cat mongodb.service | grep -i wantedby
WantedBy=multi-user.target
Disable it
To find out that if it's active (Will be run at startup/boot-time):
systemctl is-active mongodb
It's either active or inactive; In your case it should be active.
To stop it from being started at boot time we should disable it:
sudo systemctl disable mongodb
And to make sure nothing else (No other service) can start it, we mask it:
systemctl mask mongodb
so it will be linked to /dev/null and can't be started automatically or manually anymore.
I'm not aware of mongodb service name, try hitting the tab it will be completed. I guess it's mongodb ;)
Ravexina
  • 57,256
14
To know if a service is enabled at boot time, the right command is :
systemctl is-enabled apache2
enabled
You can try by yourself by changing the state with
systemctl enable apache2
systemctl disable apache2
(this isn't intended to be the answer)
Charles Green
  • 21,859
Also have a look at Settings -> Session and Startup -> Application Autostart to see if your application is mentioned there.
