27
I installed mongodb for learning purpose, the problem I am facing is that it starts on system boot and consume resources even if not being used. I want it to be removed from system boot, how can I do this?
5 Answers5
18
I can't test it at the moment, but I think this should work
 sudo update-rc.d mongodb disable
If this is not enough try this
 sudo update-rc.d -f mongodb remove
This worked for me and I'm using Ubuntu 18.04:
sudo systemctl disable mongod
This is borrowed from this answer:
echo manual | sudo tee /etc/init/mongod.override
Zanna
  • 72,312
davelupt
  • 177
@davelupt's reference is great. However I guess the command should be
since the file for MongoDB under /etc/init is mongod.conf.
Robert
  • 141
For Ubuntu 18 and above use
$ sudo systemctl stop mongod
For earlier versions
$ sudo service mongod stop
For MacOS:
$ brew services stop mongodb-community@4.2
For Windows, Open CMD as Admin:
sc.exe delete MongoDB
More info can be found here
Nditah
  • 146
