Dead links cause a message in the form of ERROR: Can't access file [dead link path] to be printed which doesn't make too much sense because it's not an error in terms of a virus scan, it's just an unimportant state of an unimportant part of the filesystem, it's a debugging or trace message.
Example:
> cd /tmp/test/
> ln -s -T /inexisting file
> sudo clamdscan --fdpass --multiscan /tmp/test/
ERROR: Can't access file /tmp/test/file
----------- SCAN SUMMARY -----------
Infected files: 0
Total errors: 1
Time: 0.000 sec (0 m 0 s)
Can I avoid this message with a built-in option of clamd? It doesn't prevent clamd from working well, but clutters up the output. I checked them and none appears convincing, but they're not overly clear in names and the configuration files wasn't commented. It's not worth to figure this out in detail or filtering the output.
Removing the links is work intensive (not only once, but every time e.g. a build process creates such links) and doesn't lead to a deterministic suppression of the issue. It's a valid temporary workaround.
I'm using 0.99.2+dfsg-2ubuntu2 on Ubuntu 16.10.
According to the man page the default is to not follow links so I think you are getting this error due to a misconfiguration of /etc/clamav/clamd.conf which I assume was edited as clamd creates it the first time it runs.
Regardless you'll want to edit the file and comment out the line.
FollowFileSymlinks (yes/true/1)<-it will have one of these equivalent boolean values
and if you don't want to follow directory symlinks either comment out the line
FollowDirectorySymlinks (yes/true/1)<-it will have one of these equivalent boolean values
as well. This should return you back to default operation and eliminate the ERROR: Can't access file /tmp/test/file
Alternatively: If you prefer, rather than commenting out the line that's deviating from default behavior you can simply choose to set it to one of the following: no, false, or 0
If that doesn't solve your problem you've discovered a bug and should report it.
Elder Geek
  • 36,752
