I want to change my monitor (Dell S2216H) brightness with commands
ddccontrol -p -r 0x10 -w 53
This command used to work on 16.10 now it doesn't, but gives this output
robing for available monitors.......
Detected monitors :
No monitor supporting DDC/CI available.
If your graphics card need it, please check all the required kernel
modules are loaded (i2c-dev, and your framebuffer driver).
Output of ddccontrol -p is same
ddccontrol version 0.4.2
Copyright 2004-2005 Oleg I. Vdovikin (oleg@cs.msu.su)
Copyright 2004-2006 Nicolas Boichat (nicolas@boichat.ch)
This program comes with ABSOLUTELY NO WARRANTY.
You may redistribute copies of this program under the terms of the GNU General Public License.
Probing for available monitors.......
Detected monitors :
Output of i2cdetect -l
i2c-3 unknown i915 gmbus dpc N/A
i2c-1 unknown i915 gmbus vga N/A
i2c-6 unknown DPDDC-D N/A
i2c-4 unknown i915 gmbus dpb N/A
i2c-2 unknown i915 gmbus panel N/A
i2c-0 unknown i915 gmbus ssc N/A
i2c-5 unknown i915 gmbus dpd N/A
Here is the output of ddcontrol -p when it used to work at pastebin
It stopped working while I was doing this process described by Jacob Vlijm, But after that I've gone through multiple fresh installs but It never worked, the only thing that seems to be different now is I'm running 17.04 but I distinctly remember it working on 16.10 and then failing on fresh installs of 16.10
More info
I2C dev interface - The Linux Kernel Archives
What are DPDDC-B/C i2c devices?
Ultimately I'm trying to achieve this but ddccontrol needs to work for that
