I'm trying to resolve a problem with wireless connectivity on my Toshiba C55-C-184 laptop. I asked about this problem here.
It looks like the problem is with the Intel Corporation Wireless 3160 network controller. I've found a couple of posts that suggest making sure that the latest versions of linux-firmware and linux-firmware-nonfree are installed.
When I install linux-firmware I get
sudo apt-get install linux-firmware
Reading package lists... Done
Building dependency tree
linux-firmware is already the newest version (1.157.8).
0 to upgrade, 0 to newly install, 0 to remove and 21 not to upgrade.
so all seems OK there. But when I try to install linux-firmware-nonfree I get the following:
sudo apt-get install linux-firmware-nonfree
E: Unable to locate package linux-firmware-nonfree
which is clearly not so good.
I did a Google search, and it seems that the package does, in fact, exist, so why can't I locate it?
As always, any help will be appreciated. Especially if you can explain why it's not working as well as how I can go about fixing it. I'm always looking to expand my working knowledge of Linux.
sempaiscuba
  • 1,453
That's not quite true. I suggest that you download and install an even newer version and see if it helps your issue. If it does not, then tell us more and we'll propose another solution.
From the terminal:
wget http://mirrors.kernel.org/ubuntu/pool/main/l/linux-firmware/linux-firmware_1.164_all.deb
sudo dpkg -i linux-firmware*.deb
Reboot and let us hear your results.
@Takkat is quite correct. Intel firmware is free and will not be found in linux-firmware-nonfree.
chili555
  • 61,330
The reason your Ubuntu release (from previous question I assume it is 16.04) can't locate this package is that it was only released for older versions, namely Precise, and Trusty of the still supported releases.
This package won't help with the Intel iwlwifi driver anyway, as the Intel drivers traditionally are Open Source and already included in the default kernel firmware packages.
So to get a newer driver I would recommend to update the kernel to the HWE kernel (What is hardware enablement (HWE)?), or install a later Ubuntu release.
Further reading:
Takkat
  • 144,580
I ran into the same problem, and found the solution:
Add a line to your /etc/apt/sources.list like this:
deb http://ftp.de.debian.org/debian stretch main non-free
I found this answer when I tried to bypass Aptitude and download directly from Debian's package index.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
in real life the packet linux-firmware-nonfree often doesnt have necessary firmwares. it's better to download firmwares directly from https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/refs/
Alex
  • 148
