I run Ubuntu 14.04 as file server for windows clients. Clients have mapped network shared folder to work with. When they delete files from that folder, files goes to ".recycle". I wanted to delete files older then x days. I used autotrash command:
autotrash -d 30 -T /home/etc/.recycle
but it tells me that .recycle doesn't contain info file:
Can not find trash information directory. Make sure you have at least GNOME 2.24
I was looking at: /home/etc/.recycle/info
Latest Gnome is installed and result are same. I understand that app can't read info when files moved into .recycle. I can use command: find /path/to/files* -mtime +5 -exec rm {} \; but when files move into .recycle they keep last modification date, not date when they move into folder.
Can I create info file? Is there any solution how can I delete files older then x days from a day when files moved into some folder?
Thanks in advance.
