I know you can use libreoffice as a command line tool and one parameter to convert formats is --convert-to, I do not know of other programs.
However, I do not know how to make it work, what do I have to type with libreoffice or another program to convert from excel to calc or the other way round?
sharkant
  • 1,361
Use the default extension to indicate what you want to convert your file to:
libreoffice --convert-to xlsx filename.ods
to convert a Calc file to Excel (this will create filename.xlsx), or
libreoffice --convert-to ods filename.xlsx
the other way around.
If you want to convert a batch of files in one go, use a *:
libreoffice --convert-to ods *.xlsx
If this doesn't work, either enter the command with sudo, or fix ownership of your .config directory (see here):
sudo chown -R --reference="$HOME" ~/.config
Jos
  • 30,529
  • 89
  • 96
