Both apt-get update and upgrade hang:
sudo apt-get update
[sudo] password for xxx:
0% [Connecting to archive.ubuntu.com (2001:67c:1360:8001::17)]
I'm able to ping archive.ubuntu.com:
PING archive.ubuntu.com (91.189.88.162) 56(84) bytes of data.
64 bytes from yukinko.canonical.com (91.189.88.162): icmp_seq=1 ttl=50 time=42.2 ms
64 bytes from yukinko.canonical.com (91.189.88.162): icmp_seq=2 ttl=50 time=42.1 ms
64 bytes from yukinko.canonical.com (91.189.88.162): icmp_seq=3 ttl=50 time=42.1 ms
^C
--- archive.ubuntu.com ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2002ms
rtt min/avg/max/mdev = 42.169/42.206/42.265/0.240 ms
I checked this question, and I don't think its the same issue.
Any tips for investigating this further?
Ravexina
  • 57,256
alf
  • 63
From your output it seems to me that it's a IPv6 problem, so we should force apt to use IPv4 instead.
If we search apt.conf (5) manual for IPv4 we will find:
ForceIPv4:
When downloading, force to use only the IPv4 protocol.
To enable this option we should create a file within:
/etc/apt/apt.conf.d/
the name can be anything for something relative we use 99force-ipv4, the number is the priority of config files within this directory.
Then add the below command to this file and save it:
Acquire::ForceIPv4 "true";
Then try updating your source again:
sudo apt update
Not sure of the cause of problem, however I think your university is running an internal IPv6 network; so apt is trying to connect with IPv6 to its mirrors, and there may be some incompatibility. I just tried forcing apt to use IPv4 and it worked.
Short instruction:
Also we can use echo and tee to write this config down with one command (from here):
echo 'Acquire::ForceIPv4 "true";' | sudo tee /etc/apt/apt.conf.d/99force-ipv4
Ravexina
  • 57,256
For me below worked:
sudo vim /etc/apt/apt.conf
Acquire::http::proxy "http://<Proxy IPaddress>:8080/";
Stephen Rauch
  • 1,156
  • 15
