32
I updated from 16.04 to 17.04 a couple days ago. After doing so I found that when I connect my Ethernet cable, it doesn't connect or show connection as it did in 16.04. I Have an HP-15 laptop. I checked for drivers in update area, but it didn't find anything related to Ethernet network.
Here is what I did: To do this - in a terminal:
sudo nano /etc/NetworkManager/NetworkManager.conf
change the line managed=false to managed=true
Save, stop and start network manager:
sudo service network-manager restart
But still have the problem.
It looks like it tries to connect to LAN wired connection but then goes directly to WiFi and connects, then doesn't show any Ethernet connection like it did in 16.04. Any help would be appreciated. I'm almost ready to revert to 16.04
Tooniis
  • 1,602
casawyer
  • 732
5 Answers5
59
According to this bug report, the solution is to add a missing configuration file to NetworkManager, then to restart it.
It worked for me :
sudo touch /etc/NetworkManager/conf.d/10-globally-managed-devices.conf
sudo systemctl restart NetworkManager
skizo
  • 731
Open an Terminal window. There are many different methods for this. The easist is to Alt + Ctrl + T at the same time.
Step 1 Type in or copy this command: sudo touch /etc/NetworkManager/conf.d/10-globally-managed-devices.conf Then press the Enter key. Now type in your user password and press the Enter key again.
Step 2 Do the same for this command: sudo systemctl restart NetworkManager
MathCubes
  • 5,732
I entered this into terminal:
entered and then rebooted and it is there.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
casawyer
  • 732
For temporary solution use
sudo dhclient
Ethernet Network not showing or connecting in Ubuntu 18.04
It is working fine. Just open the terminal and update the system using WiFi-connection:
sudo apt-get update
After compliantion of the update
clear
Now open the New terminal:
if you find any problem else more try this:
