I used Windows but uninstalled it, and installed Ubuntu 16.04. Now I have a big problem: My WiFi stopped working. I tried everything I could find, and still no WiFi. for 10 days.
My machine is :
  • Acer Aspire V13 / V3-371-55PF
  • CPU Intel Core i5-4210U 1.7 GHz with Turbo Boost ut to 2.7 GHz
  • Network controller: Qualcomm Atheros AR9462 Wireless Network Adaptor (rev 01)
  • Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0c)
First, check the settings in the router. WPA2-AES is preferred; not any WPA and WPA2 mixed mode and certainly not TKIP. Second, if your router is capable of N speeds, you may have better connectivity with a channel width of 20 MHz in the 2.4 GHz band instead of automatic 20/40 MHz, although it is likely to affect N speeds. I also have better luck with a fixed channel, either 1, 6 or 11, rather than automatic channel selection. Also, be certain the router is not set to use N speeds only; auto B, G and N is preferred. After making these changes, reboot the router.
Next, I recommend that your regulatory domain be set explicitly. Check yours:
sudo iw reg get
If you get 00, that is a one-size-maybe-fits-all setting. Find yours here: http://en.wikipedia.org/wiki/ISO_3166-1_alpha-2 Then set it temporarily:
sudo iw reg set IS
Of course, substitute your country code if not Iceland. Set it permanently:
gksudo gedit /etc/default/crda
Use nano or kate or leafpad if you don't have the text editor gedit.
Change the last line to read:
REGDOMAIN=IS
Proofread carefully, save and close the text editor.
Next, I'd set IPv6 to Ignore in Network Manager: http://docs.fedoraproject.org/en-US/Fedora/18/html/Installation_Guide/images/netconfig/network-connections-ipv6-ignore.png This example is for ethernet, but you want wireless.
If these changes do not help, please try:
sudo modprobe -r ath9k
sudo modprobe ath9k nohwcrypt=1
If it helps, make it permanent:
sudo -i
echo "options ath9k nohwcrypt=1"  >>  /etc/modprobe.d/ath9k.conf
exit
chili555
  • 61,330
I've got the same laptop running ubuntu gnome 16.04, the wifi would connect to my home network but be completely unusable. Within seconds of connecting I'd be getting 70-90% packet loss with pings in the 1000's ms, often dropping from that to timeouts and something like a buffer error.
The fix for me was disabling the 802.11'n' features on the card, the issue stopped straight away and the wifi hasn't had an issue for weeks now.
I believe this was the post I got it from, the iwlwifi part halfway down. How do I keep my Wifi from dropping out? - Ask Ubuntu
Jeff
