Update: I've decided to return the card as there doesn't seem to be any linux firmware support to date.
I can't get my Wifi card (ASUS_PCE-AC88) to work on Ubuntu 16.04 The card does not show up in the network manager.
I've created this question specifically because I haven't found any good information on ubuntu drivers for [14e4:43c3] yet. The thread on askubuntu about broadcom drivers (Installing Broadcom Wireless Drivers) does not list my version.
Please let me know if you need any more information.
I've already tried installing bcmwl-kernel-source and loading the module wl via sudo modprobe wl which resulted in an error on boot:
ERROR @wl_cfg80211_detach : NULL ndev->ieee80211ptr, unable to deref
I'm running the following kernel version: 4.4.0-72-generic
Info on the chip:
lspci -vnn | grep Network
02:00.0 Network controller [0280]: Broadcom Limited Device [14e4:43c3]
(rev 04)
lshw -class network
*-network UNCLAIMED
   Beschreibung: Network controller
   Produkt: Broadcom Limited
   Hersteller: Broadcom Limited
   Physische ID: 0
   Bus-Informationen: pci@0000:02:00.0
   Version: 04
   Breite: 64 bits
   Takt: 33MHz
   Fähigkeiten: pm msi pciexpress cap_list
   Konfiguration: latency=0
   Ressourcen: memory:feaf8000-feafffff memory:fe000000-fe7fffff
memory:fb800000-fbbfffff
More info on the card: https://wikidevi.com/wiki/ASUS_PCE-AC88
Update:
dmesg | grep brcm
[   13.868848] usbcore: registered new interface driver brcmfmac
[   14.001095] brcmfmac 0000:02:00.0: Direct firmware load for
brcm/brcmfmac4366b-pcie.txt failed with error -2
[   16.403501] brcmf_pcie_download_fw_nvram: FW failed to initialize
Running sudo modprobe -r wl and sudo modprobe brcmfmac did not print anything to the console. (Wifi card is still UNCLAIMED and does not appear in network manager.)
Update 2
modinfo brcmfmac | grep firmware
firmware:       brcm/brcmfmac4354-sdio.txt
firmware:       brcm/brcmfmac4354-sdio.bin
firmware:       brcm/brcmfmac43455-sdio.txt
firmware:       brcm/brcmfmac43455-sdio.bin
firmware:       brcm/brcmfmac43430-sdio.txt
firmware:       brcm/brcmfmac43430-sdio.bin
firmware:       brcm/brcmfmac4339-sdio.txt
firmware:       brcm/brcmfmac4339-sdio.bin
firmware:       brcm/brcmfmac43362-sdio.txt
firmware:       brcm/brcmfmac43362-sdio.bin
firmware:       brcm/brcmfmac4335-sdio.txt
firmware:       brcm/brcmfmac4335-sdio.bin
firmware:       brcm/brcmfmac43340-sdio.txt
firmware:       brcm/brcmfmac43340-sdio.bin
firmware:       brcm/brcmfmac4334-sdio.txt
firmware:       brcm/brcmfmac4334-sdio.bin
firmware:       brcm/brcmfmac4330-sdio.txt
firmware:       brcm/brcmfmac4330-sdio.bin
firmware:       brcm/brcmfmac4329-sdio.txt
firmware:       brcm/brcmfmac4329-sdio.bin
firmware:       brcm/brcmfmac43241b5-sdio.txt
firmware:       brcm/brcmfmac43241b5-sdio.bin
firmware:       brcm/brcmfmac43241b4-sdio.txt
firmware:       brcm/brcmfmac43241b4-sdio.bin
firmware:       brcm/brcmfmac43241b0-sdio.txt
firmware:       brcm/brcmfmac43241b0-sdio.bin
firmware:       brcm/brcmfmac43143-sdio.txt
firmware:       brcm/brcmfmac43143-sdio.bin
firmware:       brcm/brcmfmac43569.bin
firmware:       brcm/brcmfmac43242a.bin
firmware:       brcm/brcmfmac43236b.bin
firmware:       brcm/brcmfmac43143.bin
firmware:       brcm/brcmfmac4371-pcie.txt
firmware:       brcm/brcmfmac4371-pcie.bin
firmware:       brcm/brcmfmac4366b-pcie.txt
firmware:       brcm/brcmfmac4366b-pcie.bin
firmware:       brcm/brcmfmac4365b-pcie.txt
firmware:       brcm/brcmfmac4365b-pcie.bin
firmware:       brcm/brcmfmac4358-pcie.txt
firmware:       brcm/brcmfmac4358-pcie.bin
firmware:       brcm/brcmfmac43570-pcie.txt
firmware:       brcm/brcmfmac43570-pcie.bin
firmware:       brcm/brcmfmac4356-pcie.txt
firmware:       brcm/brcmfmac4356-pcie.bin
firmware:       brcm/brcmfmac4350-pcie.txt
firmware:       brcm/brcmfmac4350-pcie.bin
firmware:       brcm/brcmfmac43602-pcie.txt
firmware:       brcm/brcmfmac43602-pcie.bin
parm:           fcmode:mode of firmware signalled flow control (int)
pbz
  • 51
I know this is an old thread but support for this card is now in the latest version of Ubuntu.
I just installed Ubuntu server 19.04 and the card worked out of the box.
Beware it did not work at all with the new installer which crashes on boot and I could not get to work, so use the alternative installer instead.
chrismacp
  • 136
As you can see from the Wikidevi page that you linked, the correct driver for your device is brcmfmac; not the proprietary driver wl provided by bcmwl-kernel-source. In dmesg, it shows that the driver loaded but the required firmware wasn't found.
I believe that the latest version of linux-firmware has the needed file. With a working internet connection by ethernet, tether or whatever means possible, please open a terminal and do:
wget http://mirrors.kernel.org/ubuntu/pool/main/l/linux-firmware/linux-firmware_1.164_all.deb
sudo dpkg -i linux-firmware*.deb
Reboot and let us see:
dmesg | grep brcm
chili555
  • 61,330
