When I attempt to install MariaDB Server on my Ubuntu Server 16.04.2 with apt install mariadb-server, I get the following response:
Reading package lists... Done
Building dependency tree
 mariadb-server-10.0 : Depends: libdbi-perl but it is not going to be installed
                       Depends: mariadb-client-10.0 (>= 10.0.29-0ubuntu0.16.04.1) but it is not going to be installed
                       Recommends: libhtml-template-perl but it is not going to be installed
I did try on another instance (virtual machine, same HW) of the same OS. Over there I have no issues and the MariaDB seems to be installing fine.
Can you please suggest how I can fix the issue and install MariaDB-server on my Ubuntu?
I tried already:
sudo apt-get autoclean
sudo apt-get autoremove
sudo apt update
sudo apt-get --fix-broken install
sudo apt upgrade
sudo dpkg --configure -a
Thank you.
Mobby Dick
Have you tried including the dependencies? Like this:
sudo apt-get install mariadb-server libdbi-perl mariadb-client-10.0
There is already a similar question about this. Take a look at this link: How do I resolve unmet dependencies after adding a PPA?
Regards
