While using windows i changed my hard disk partitions from "Logical Disk" to "Dynamic Disk"..... then i installed Ubuntu in c drive. when i opened ubuntu the contents of C:Drive are shown but i am unable to view the contents of D drive or e drive (both of them are dynamic). Please help.. i tried reinstalling ubuntu quite a number of times which didn't help. Also The windows disk partition manager is unable to change the drives back to Logical Drive.. What should I do??
bain
  • 12,200
"Dynamic Disks" are a Windows proprietary format that can not be used on other operating systems like Ubuntu. You need to convert it back to a basic disk in Windows.
psusi
  • 38,031
First, you need to change a dynamic disk back to a basic disk. You can do this either through the Windows interface, or using the command-line.
Using the Windows interface
  1. Back up all volumes on the disk you want to convert from dynamic to basic.
  2. Open Computer Management (Local).
  3. In the console tree, click Computer Management (Local), click Storage, and then click Disk Management.
  4. Right-click each volume on the dynamic disk you want to convert to a basic disk, and then click Delete Volume for each volume on the disk.
  5. When all volumes on the disk have been deleted, right-click the disk, and then click Convert To Basic Disk.
Using a command line
For more information about backing up volumes, see Related Topics.
Open Command Prompt.
Type:
diskpart
At the DISKPART prompt, type:
list disk
Make note of the dynamic disk you want to convert to a basic disk.
select diskn
detail diskn
For each volume on the disk, at the DISKPART prompt, type:
select volume=n
and then type:
delete volume
select diskn
Specify the disk number of the disk that you want to convert to a basic disk.
convert basic
One Zero
  • 27,761
