So i want to install Ubuntu and im booting from USB. Im new to Ubuntu.
When i click SOMETHING ELSE, it shows 4 partions: the first of 1mb, sda1, unknown free space, second of 100mb sda2 (that i know its system recovery from win7), third is 170gb (win7) sda3, and the last one is like 830gb, i dont know where this came from.... on windows i have them separated.
is this a bug or something? How to install without losing all my data and keeping Win7?
When i try without installing i get to see my 3 partions (170gb, 600gb, 230gb) but not when i try to install.
Edit
ubuntu@ubuntu:~$ sudo gdisk -l /dev/sda
outputs this:
GPT fdisk (gdisk) version 0.8.7
Partition table scan:
MBR: MBR only
BSD: not present
APM: not present
GPT: not present
Found invalid GPT and valid MBR; converting MBR to GPT format
in memory.
Disk /dev/sda: 1953525168 sectors, 931.5 GiB
Logical sector size: 512 bytes
Disk identifier (GUID): 2729AEE7-A594-4A07-91DF-96116B581067
Partition table holds up to 128 entries
First usable sector is 34, last usable sector is 1953525134
Partitions will be aligned on 8-sector boundaries
Total free space is 2044 sectors (1022.0 KiB)
Number Start (sector) End (sector) Size Code Name
1 63 2047 992.5 KiB 4200 Windows LDM data
2 2048 206847 100.0 MiB 4200 Windows LDM data
3 206848 245762047 117.1 GiB 4200 Windows LDM data
4 245762048 1953523119 814.3 GiB 4200 Windows LDM data
And,
ubuntu@ubuntu:~$ sudo fdisk -l
outputs this:
Disk /dev/sda: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders, total 1953525168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk identifier: 0x13344b63
Device Boot Start End Blocks Id System
/dev/sda1 63 2047 992+ 42 SFS
Partition 1 does not start on physical sector boundary.
/dev/sda2 * 2048 206847 102400 42 SFS
/dev/sda3 206848 245762047 122777600 42 SFS
/dev/sda4 245762048 1953523119 853880536 42 SFS
