I am trying to setup a test web server My machine is a windows 10 I installed virtualbox -> then ubuntu -> mysql -> apache2 -> php
I am able to test like this in my ubuntu http://localhost/info.php -> working
I am not sure how to connect from my windows box to my web server on ubuntu. Thanks so much for helping me
cat interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
#iface lo inet loopback
iface lo inet static
address 192.168.1.1
netmask 255.255.255.0
gateway 192.168.1.1
*ifconfig
enp0s3: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 10.0.2.15  netmask 255.255.255.0  broadcast 10.0.2.255
        inet6 fe80::55d:fcc7:9636:c597  prefixlen 64  scopeid 0x20<link>
        ether 08:00:27:8d:b4:be  txqueuelen 1000  (Ethernet)
        RX packets 10205  bytes 10467155 (10.4 MB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 3596  bytes 442501 (442.5 KB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 464  bytes 63031 (63.0 KB)
        TX packets 464  bytes 63031 (63.0 KB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0*
Panther
  • 104,528
Khoa Nguyen
As your output indicates, you have only one interface which is set to use NAT.
To be able to send request from your host to your Ubuntu, you should create a Host-only network, and a new interface for your VM, then attach your VM to this network which your host is sitting on it too.
Create a host-only network:
In VirtualBox from file menu select preferences and in VirtualBox Preferences window, select Network, then host only networks.
After all by clicking on + plus sign add a new host-only network. it's name should be vboxnet0.
Run DHCP server
Then double click on it and go to DHCP tab to run a DHCP Server on this network, do your desired configuration as follow:
Create a new interface
Then you should add an interface to your Ubuntu VM and attach it to this network.
Do a right click on your Ubuntu VM, select settings, go to network section. Click on Adapter 2, check Enable Network Adapter and for Attached to select Host-Only adapter.
After all click ok to save these settings.
Now when you turn this VM on, you have a new interface, something like: enp0s9 which it should have an IP between 192.168.56.10 to 100, it should be 192.168.56.10. use ip a or ifconfig -a to find it out.
Config Apache
Now make apache to listen to this IP by changing apache configuration file to something like:
Listen 0.0.0.0:80
Or exactly your own IP, like:
Listen 192.168.56.10:80
Some part of this answer, and pictures are from my other answer related to VirtualBox from here.
Ravexina
  • 57,256
