SHORTCUT
Make sure you do not have any version of Google Earth on your system
sudo apt-get purge google-earth-stable
Have aptitude installed
sudo apt-get update && sudo apt-get install aptitude
Download the latest version of Google Earth
Select .64 bit deb file and Hit Agree and Download
Downgrade your system by hitting 'n', then 'y', 'y
- see further down for exact details of specific output
Then run
sudo dpkg -i "NAMEOFYOURDEB.deb"
To install all necessary packages for it. It will tell you if you need to install something else.
Finally finish installing it by running
sudo gdebi "name_of_your_current_release".deb
"only use sudo if not root"
LONGER EXPLANATION
Assumptions of what I had installed on my machine and am assuming you have on yours:
- I had aptitude installed.
- I did not google-earth on my system. It was
completely removed.
- I downloaded a current stable .deb file on my system
Only Run Commands Below this Line After Reading Below
You should see Google Earth in Menu Bar when you search "google earth"
______READ____ME_____FIRST____________
These are the Steps to follow for downgrading.
I downgraded my system because in order to run google earth they require you to have lib-core and that apparently is not supported anymore so run
sudo aptitude -f install lsb-core
Then you would enter No, when first asked and then you would enter Yes.
- The reason why, you would enter no first is because if you respond 'no', it would simply not change anything and you will still get the 'lsb-core' error
The following NEW packages will be installed: alien{a} at{a}
lib32z1{a} librpmbuild3{a} librpmsign1{a} lsb-core pax{a} rpm{ab} 0
packages upgraded, 8 newly installed, 0 to remove and 1 not upgraded.
Need to get 493 kB of archives. After unpacking 1,611 kB will be used.
The following packages have unmet dependencies: rpm : Depends: rpm-common (= 4.10.1-2.1ubuntu1) but 4.12.0.1+dfsg1-3build3 is installed. The following actions will resolve these dependencies:
Keep the following packages at their current version:
1)alien [Not Installed]
2)lsb-core[Not Installed]
3) rpm [Not Installed]
Accept this solution? [Y/n/q/?] n
these dependencies:
Downgrade the following packages: 1) rpm-common [4.12.0.1+dfsg1-3build3 (now) -> 4.10.1-2.1ubuntu1
(raring)] 2) rpm2cpio [4.12.0.1+dfsg1-3build3 (now) ->
4.10.1-2.1ubuntu1 (raring)]
Accept this solution? [Y/n/q/?] y
The following packages will be
DOWNGRADED: rpm-common rpm2cpio The following NEW packages will be
installed: alien{a} at{a} lib32z1{a} librpmbuild3{a} librpmsign1{a}
lsb-core pax{a} rpm{a} 0 packages upgraded, 8 newly installed, 2
downgraded, 0 to remove and 1 not upgraded. Need to get 523 kB of
archives. After unpacking 1,696 kB will be used.
Do you want to continue? [Y/n/?] y
