I'm trying to install Google Earth on Ubuntu 14.04 and get the following error. The problem show up using dpkg -i to install the .deb downloades from Google site, beside I tested with Ubuntu Software Center too.
Exists similar questions in this site talking about installation problems, but none of them are on 14.04, so I decided post a new questions seeking for tips-solutions for the current LTS Ubuntu version (most comments and suggestion in those previous questions are targeted oldest Ubuntu versions)
Preparing to unpack google-earth-stable_current_amd64.deb ...
Unpacking google-earth-stable (7.1.2.2041-r0) ... dpkg: dependency
problems prevent configuration of google-earth-stable:
google-earth-stable depends on lsb-core (>= 3.2); however: Package
lsb-core is not installed. google-earth-stable depends on ia32-libs;
however: Package ia32-libs is not installed.
dpkg: error processing package google-earth-stable (--install):
dependency problems - leaving unconfigured Processing triggers for
man-db (2.6.7.1-1) ... Processing triggers for bamfdaemon
(0.5.1+14.04.20140409-0ubuntu1) ... Rebuilding
/usr/share/applications/bamf-2.index... Processing triggers for
gnome-menus (3.10.1-0ubuntu2) ... Processing triggers for
desktop-file-utils (0.22-1ubuntu1) ... Processing triggers for
mime-support (3.54ubuntu1) ... Errors were encountered while
processing: google-earth-stable
Doing what is described here I got:
sudo dpkg -i google-earth-stable_current_amd64.deb Selecting
previously unselected package google-earth-stable. (Reading database
... 277661 files and directories currently installed.) Preparing to
unpack google-earth-stable_current_amd64.deb ... Unpacking
google-earth-stable (7.1.2.2041-r0) ... dpkg: dependency problems
prevent configuration of google-earth-stable: google-earth-stable
depends on lsb-core (>= 3.2); however: Package lsb-core is not
installed. google-earth-stable depends on ia32-libs; however:
