I accidentally installed ubuntu-gnome-desktop (initially with lightdm, and later switched to gdm3) on my heavily customized Ubuntu (Unity) 16.10 environment. Yikes! Now a bunch of stuff in Unity doesn't work as it did before. I need help fixing some unresolved problems. Can you please help?
  1. Desktop problems
    • In Unity, I can't set desktop background
    • In Unity, the superkey doesn't bring up dashboard unless another application is in the foreground
    • In Unity, the desktop files and folders are gone
    • In Unity, I can't right-click on the desktop and bring up the contextual menu
  2. Font problem
    • In Unity, the default fonts have changed
  3. Touchpad problems
    • In Unity, the touchpad-indicator crashes, looking for Synaptics touchpad driver
    • In Unity, the touchpad "tap to single-left-click" no longer works
    • In Unity, the touchpad preferences are missing in System Settings/Mouse & Touchpad panel
    • In Gnome, the touchpad preferences do show up in System Settings
I believe that this is because xserver-xorg-input-libinput got installed, thereby disabling the Synaptics touchpad driver. Can I safely uninstall this, and hopefully re-enable the Synaptics driver, without breaking anything in the Unity desktop, or the Gnome desktop?
  1. Login screen problem
    • The main login screen background is black. How do I get any background to show again?
  2. Default DE problem
    • The login area always shows "Gnome (Default)" in the list of desktop environments. How do I change the default to "Ubuntu (Default)"?
  3. Boot/shutdown screens problem
    • Boot and shutdown screens are Gnome animation/text screens. How do I bring back normal Ubuntu/Unity boot/shutdown screens?
heynnema
  • 73,649
Fixes for my ubuntu-gnome-desktop post-installation problems...
  1. Desktop problems: Use the Gnome Tweak Tool, and set "Icons on Desktop" to ON
  2. Font problem: Use the Unity Tweak Tool, and set the fonts back to Ubuntu default fonts
  3. Touchpad problems: Fix taken from How to invert touchpad scrolling on Ubuntu 16.04
If you use libinput, then add a config file to /etc/X11/xorg.conf.d/ such as 20-touchpad.conf with this content:
Section "InputClass"
    Identifier "libinput touchpad catchall"
        MatchIsTouchpad "on"
        MatchDevicePath "/dev/input/event*"
        Driver "libinput"
        Option "NaturalScrolling" "off"
        Option "MiddleEmulation" "on"
        Option "Tapping" "on"
        Option "DisableWhileTyping" "on"
        Option "PalmDetection" "True"
EndSection
  1. Login screen problem: User desktop must be set to display a desktop picture, not a solid color
  2. Default DE problem:
In terminal...
gksudo gedit /etc/lightdm/lightdm.conf
add in this text snippet under [SeatDefaults]...
[SeatDefaults]
user-session=ubuntu
don't duplicate [SeatDefaults] if it's already there.
  1. Boot/shutdown screens problem: Partially taken from How do I revert the Plymouth theme back to default after purging Kubuntu?
In terminal...
ls -al /etc/alternatives/*plymouth*
sudo update-alternatives --config default.plymouth
sudo update-alternatives --config text.plymouth
heynnema
  • 73,649
The Touchpad problem could be resolved by removing the xserver-xorg-input-libinput package.
sudo apt remove xserver-xorg-input-libinput
I had the same problem and removing package solved it without making any other problems. Note: I have removed Gnome Shell completely before removing this package.
Source: this Ubuntu Forums post
Hamed
  • 566
