My server has not been running cron jobs since March 25, though it was running before that day and nothing has changed.
The OS version is Ubuntu 8.04LTS.
First, I restarted cron and checked processes.
$ sudo /etc/init.d/cron restart
 * Restarting periodic command scheduler crond
   ...done
$ ps aux | grep cron
root     14893  0.0  0.0  19640   908 ?        Ss   14:50   0:00 /usr/sbin/cron
user     16144  0.0  0.0   4972   844 pts/0    R+   14:50   0:00 grep cron
$ pgrep cron
14893
It seems that the cron process is running but when I checked status:
$ /etc/init.d/cron status
 * Usage: /etc/init.d/cron {start|stop|restart|reload|force-reload}
I guess there's something wrong.
I checked syslog
$ less /var/log/syslog | grep CRON
Mar 25 07:50:01 mail /USR/SBIN/CRON[12406]: (user) CMD (/home/user/public_html/rails_app/current/script/runner -e production "NewsRelease.send_unnoticed_mails" >> /home/user/public_html/rails_app/current/log/cron.log 2>&1)
Mar 25 07:50:01 mail /USR/SBIN/CRON[12409]: (user) CMD (/home/user/public_html/rails_app/current/script/runner -e production "Link.send_unnoticed_mails" >> /home/user/public_html/rails_app/current/log/cron.log 2>&1)
Apr  7 11:47:19 mail /usr/sbin/cron[13954]: (CRON) INFO (pidfile fd = 3)
Apr  7 11:47:19 mail /usr/sbin/cron[13955]: (CRON) STARTUP (fork ok)
Apr  7 11:47:19 mail /usr/sbin/cron[13955]: (CRON) INFO (Skipping @reboot jobs -- not system startup)
The logs after Apr 7 are logs when I run commands for cron manually.
Therefore cron has not been running since Mar 25.
My crontab file is below. It is to execute rails and ruby methods. These jobs were running successfully before March 25.
# Begin Whenever generated tasks for: rails_app
PATH=/usr/loca/sbin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/games
50 7 * * * /home/user/public_html/rails_app/current/script/runner -e production "Link.send_unnoticed_mails" >> /home/user/public_html/rails_app/current/log/cron.log 2>&1
0 5 * * * /home/user/mysql_backup.sh >> /home/user/public_html/rails_app/current/log/cron.log 2>&1
0,15,30,45 * * * * /home/user/public_html/rails_app/current/script/runner -e production "Tweet.post_tweet_at" >> /home/user/public_html/rails_app/current/log/cron.log 2>&1
# End Whenever generated tasks for: rails_app
Zanna
  • 72,312
If I read the comments correctly, you're looking for a temporary fix while you get a new server running a supported OS up and running. In that case, you might try the following
Create a script that will run an infinite loop to make your calls instead of trying to fix cron on a very obsolete OS. Something like this should do.
#!/bin/bash
while true
do
    time=$(date +%H:%M)
    hr=$(cut -f1 -d: <<< "$time")
    min=$(cut -f2 -d: <<< "$time")
    if [ "$hr" == "07"] && [ "$min" == "50" ]; then
        #run something at 7:50am
    fi
    if [ "$hr" == "05" ] && [ "$min" == "00" ]; then
        #run something at 5am
    fi
    if [ "$((min % 15))" == "0" ]; then
        #run something every quarter hour
    fi
    sleep 60
done
Then of course there is the task of running this at boot time. My 8.04 days are long past, and I can't say what worked back then. Take a look at this post though, and see if it gets you where you want to be.
b_laoshi
  • 4,868
  • 26
  • 49
