Output of lsusb and sane-find-scanner below:
janos@AndrasXubuntu:~/Desktop$ sane-find-scanner
# sane-find-scanner will now attempt to detect your scanner. If the
# result is different from what you expected, first make sure your
# scanner is powered up and properly connected to your computer.
# No SCSI scanners found. If you expected something different, make sure that
# you have loaded a kernel SCSI driver for your SCSI adapter.
found USB scanner (vendor=0x03f0 [Hewlett-Packard], product=0x1205 [hp scanjet scanner]) at libusb:002:002
could not open USB device 0x1d6b/0x0001 at 002:001: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0001 at 001:001: Access denied (insufficient permissions)
# Your USB scanner was (probably) detected. It may or may not be supported by
# SANE. Try scanimage -L and read the backend's manpage.
# Not checking for parallel port scanners.
# Most Scanners connected to the parallel port or other proprietary ports
# can't be detected by this program.
# You may want to run this program as root to find all devices. Once you
# found the scanner devices, be sure to adjust access permissions as
# necessary.
janos@AndrasXubuntu:~/Desktop$ scanimage -L
[hp5590] hp5590_get_status: USB-in-USB: got non-zero device status (status 12)
[hp5590] hp5590_init_scanner: scanner reports non-zero status: Device busy
No scanners were identified. If you were expecting something different,
check that the scanner is plugged in, turned on and detected by the
sane-find-scanner tool (if appropriate). Please read the documentation
which came with this software (README, FAQ, manpages).
Additional info:
(1) gscan2pdf and xsane has the same problem - cannot find device
(2) when I had xubuntu 12.04 scanner worked
(3) if I connect my laptop (same Ubuntu 16.04 as the desktop, but laptop is 64 bit, desktop is 32 bit) then simple scan on laptop works.
Sudo output, see comment below by janos
janos@AndrasXubuntu:~/Desktop$ sudo sane-find-scanner
[sudo] password for janos:
janos@AndrasXubuntu:~/Desktop$ sudo scanimage -L
Output of lsusb (sorry, I meant to include that the first time when I saked the question)
janos@AndrasXubuntu:~/Desktop$ sudo lsusb
Bus 002 Device 002: ID 03f0:1205 Hewlett-Packard ScanJet 4500C/5550C
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Please note that if I plug the scanner to a different usb socket (e.g. a socket in Bus 001) lsusb will find it there but simple-scan still would not work.
Additional info:
I can dual boot this machine to an old installation of Fedora-3. Scanner works there. However, scanimage -L will not find it, lsusb and sane-find-scanner does. See below output of terminal in Fedora-3 boot.
[apu@andraslinux ~]$ su -c "scanimage -L"
Password:
[apu@andraslinux ~]$ /sbin/lsusb
[apu@andraslinux ~]$ sane-find-scanner
# you have loaded a SCSI driver for your SCSI adapter.
Could it be the libusb that enables FC3 to run scanner but Ubuntu 16.04 may not use libusb?
As I mentioned before scanner did work on 12.04 but stopped working after upgrading to 14.04 and now to 16.04
Additional info regarding libusb:
Terminal output is identical for both the 32bit desktop (scanner not working) and 64bit laptop (scanner working), and is here below:
janos@acerlinux:~/Desktop$ dpkg -l libusb
dpkg-query: no packages found matching libusb
In fact, I just checked that my 64bit laptop does not have libsane-dev, and checked again, scanner works if connected to leptop.
Additional info copied here from comments below:
/etc/sane.d/dll.conf was OK, hp5590 was not commented; then I modified /etc/sane.d/hp5400.conf by adding the proper usb line; scanner still not working even though scanimage -L detects it, but reports as busy. See here:
One more thing, interestingly, the /etc/sane.d/hp5400.conf file is the same on both 64bit laptop and 32bit Fc3 desktop without having the edited addition of 5590 usb line and yet both work with the scanner except the 32bit Ubuntu desktop since upgrading from 12.04.
Consequently, I think the big question is "Why 32bit 16.04 Ubuntu desktop reports device busy?"
Additional info - revised output of libusb, this time with asterisk:
libusb on 32bit desktop
janos@AndrasXubuntu:~/Desktop$ dpkg -l libusb*
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii libusb-0.1-4:i 2:0.1.12-28 i386 userspace USB programming library
ii libusb-1.0-0:i 2:1.0.20-1 i386 userspace USB programming library
un libusb-dev <none> <none> (no description available)
un libusbmuxd-too <none> <none> (no description available)
ii libusbmuxd4:i3 1.0.10-2ubun i386 USB multiplexor daemon for iPhone
libusb on 64bit laptop:
janos@acerlinux:~/Desktop$ dpkg -l libusb*
ii libusb-0.1-4:a 2:0.1.12-28 amd64 userspace USB programming library
ii libusb-1.0-0:a 2:1.0.20-1 amd64 userspace USB programming library
ii libusbmuxd4:am 1.0.10-2ubun amd64 USB multiplexor daemon for iPhone
Additional info:
According to my notes for FC3 and man sane-usb usbfs has to be mounted in order for scanner to work. So in my FC3 I have a line in fstab containing
none /proc/bus. Consequently I looked at the mounted filesystems on 32bit Ubuntu and 64bit Ubuntu. See below comparisons:
32 bit Ubuntu df -ha
janos@AndrasXubuntu:~/Desktop$ sudo df -ha
Filesystem Size Used Avail Use% Mounted on
sysfs 0 0 0 - /sys
proc 0 0 0 - /proc
udev 482M 0 482M 0% /dev
devpts 0 0 0 - /dev/pts
tmpfs 100M 5.1M 95M 6% /run
/dev/sda1 9.1G 4.0G 4.7G 47% /
securityfs 0 0 0 - /sys/kernel/security
tmpfs 500M 108K 500M 1% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 500M 0 500M 0% /sys/fs/cgroup
cgroup 0 0 0 - /sys/fs/cgroup/systemd
pstore 0 0 0 - /sys/fs/pstore
cgroup 0 0 0 - /sys/fs/cgroup/blkio
cgroup 0 0 0 - /sys/fs/cgroup/cpu,cpuacct
cgroup 0 0 0 - /sys/fs/cgroup/cpuset
cgroup 0 0 0 - /sys/fs/cgroup/net_cls,net_prio
cgroup 0 0 0 - /sys/fs/cgroup/freezer
cgroup 0 0 0 - /sys/fs/cgroup/memory
cgroup 0 0 0 - /sys/fs/cgroup/hugetlb
cgroup 0 0 0 - /sys/fs/cgroup/pids
cgroup 0 0 0 - /sys/fs/cgroup/perf_event
cgroup 0 0 0 - /sys/fs/cgroup/devices
systemd-1 0 0 0 - /proc/sys/fs/binfmt_misc
hugetlbfs 0 0 0 - /dev/hugepages
debugfs 0 0 0 - /sys/kernel/debug
mqueue 0 0 0 - /dev/mqueue
fusectl 0 0 0 - /sys/fs/fuse/connections
tmpfs 100M 4.0K 100M 1% /run/user/108
tmpfs 100M 36K 100M 1% /run/user/1000
gvfsd-fuse 0.0K 0.0K 0.0K - /run/user/1000/gvfs
Comparing files on 32bit desktop between FC3 (where scanner works) and Ubuntu
janos@AndrasXubuntu:/media/janos/_1/etc/sane.d$ diff hp5400.conf /etc/sane.d/hp5400.conf
14c14
< #/dev/usb/scanner0
> #/dev/usbscanner
64bit Ubuntu df -ha
janos@acerlinux:~/Desktop$ sudo df -ha
sysfs 0 0 0 - /sys
proc 0 0 0 - /proc
udev 1.4G 0 1.4G 0% /dev
tmpfs 276M 5.0M 271M 2% /run
/dev/sda5 17G 7.1G 8.5G 46% /
tmpfs 1.4G 260K 1.4G 1% /dev/shm
tmpfs 1.4G 0 1.4G 0% /sys/fs/cgroup
systemd-1 - - - - /proc/sys/fs/binfmt_misc
/dev/sda7 3.0G 1.3G 1.7G 44% /mnt/DOS_E
/dev/sda8 22G 6.1G 15G 30% /mnt/save
binfmt_misc 0 0 0 - /proc/sys/fs/binfmt_misc
tmpfs 276M 44K 276M 1% /run/user/1000
FC3 df -ha
/dev/hdb1 18G 7.0G 11G 41% /
none 0 0 0 - /proc
none 0 0 0 - /sys
none 0 0 0 - /dev/pts
none 506M 0 506M 0% /dev/shm
none 0 0 0 - /proc/bus/usb
none 0 0 0 - /proc/sys/fs/binfmt_misc
none 0 0 0 - /var/named/chroot/proc
FC3 ls | grep hp5400.conf
hp5400.conf
FC3 ls | grep hp 5550.conf has no output.
Consequently, things noted: (a) neither FC3 nor 64bit Ubuntu laptop has hp5550.conf files yet scanner with both machines work, (b) while neither 32bit nor 64bit Ubuntu has usbfs mounted scanner works on 64bit Ubuntu but not on 32bit Ubuntu.
Additional info on trying proposed package:
janos@AndrasXubuntu:~/Desktop$ sudo dpkg -i libsane-dev_1.0.25+git20150528-1ubuntu2.16.04.1_i386.deb
(Reading database ... 196333 files and directories currently installed.)
Preparing to unpack libsane-dev_1.0.25+git20150528-1ubuntu2.16.04.1_i386.deb ...
Unpacking libsane-dev (1.0.25+git20150528-1ubuntu2.16.04.1) over (1.0.25+git20150528-1ubuntu2) ...
dpkg: dependency problems prevent configuration of libsane-dev:
libsane-dev depends on libsane (= 1.0.25+git20150528-1ubuntu2.16.04.1); however:
Version of libsane:i386 on system is 1.0.25+git20150528-1ubuntu2.
dpkg: error processing package libsane-dev (--install):
dependency problems - leaving unconfigured
Processing triggers for doc-base (0.10.7) ...
Processing 1 changed doc-base file...
Processing triggers for man-db (2.7.5-1) ...
libsane-dev
janos@AndrasXubuntu:~/Desktop$ sudo dpkg -i libsane_1.0.25+git20150528-1ubuntu2.16.04.1_i386.deb
Preparing to unpack libsane_1.0.25+git20150528-1ubuntu2.16.04.1_i386.deb ...
Unpacking libsane:i386 (1.0.25+git20150528-1ubuntu2.16.04.1) over (1.0.25+git20150528-1ubuntu2) ...
dpkg: dependency problems prevent configuration of libsane:i386:
libsane:i386 depends on libsane-common (= 1.0.25+git20150528-1ubuntu2.16.04.1); however:
Version of libsane-common on system is 1.0.25+git20150528-1ubuntu2.
dpkg: error processing package libsane:i386 (--install):
Processing triggers for libc-bin (2.23-0ubuntu7) ...
libsane:i386
