Can nano do syntax highlighting like gedit and vim? How can I enable it? I need at least bash and python syntax highlights.
The nano editor provides syntax highlighting for a few languages and scripts by itself. Check out /usr/share/nano/
nits@nits-excalibur:~$ ls /usr/share/nano/
asm.nanorc fortran.nanorc man.nanorc ocaml.nanorc ruby.nanorc
awk.nanorc gentoo.nanorc mgp.nanorc patch.nanorc sh.nanorc
c.nanorc groff.nanorc mutt.nanorc perl.nanorc tcl.nanorc
cmake.nanorc html.nanorc nano-menu.xpm php.nanorc tex.nanorc
css.nanorc java.nanorc nanorc.nanorc pov.nanorc xml.nanorc
debian.nanorc makefile.nanorc objc.nanorc python.nanorc
Link them to your user's nano configuration file (present at ~/.nanorc, ${XDG_CONFIG_HOME}/nano/nanorc, or ~/.config/nano/nanorc, whichever is encountered first) with something similiar to this line:
nits@nits-excalibur:~$ cat ~/.nanorc
include /usr/share/nano/sh.nanorc
Now, syntax highlighting is enabled in nano for whatever file you linked (You could also link multiple files)
Note: Sometimes you might get a segmentation fault after you have edited your ~/.nanorc file. If such an error occurs, unsetting the LANG environment variable helps. You can unset it with unset LANG in the terminal. (Solution obtained from here)
There are also other solutions if you are not satisfied with your bash highlighting. One example of such can be found here
You can also write include /usr/share/nano/* to the ~/.nanorc file to enable all languages to be highlighted if your nano version supports it.
- 103
- 22,739
Yes you can, however the default syntax definitions are quite poor and incomplete. I'm maintaining a more accurate set of definitions here, for anyone who finds them useful.
To install, run:
git clone https://github.com/scopatz/nanorc.git
cd nanorc
make install
Add these lines to the ~/.nanorc
include ~/.nano/syntax/html.nanorc
include ~/.nano/syntax/css.nanorc
include ~/.nano/syntax/php.nanorc
include ~/.nano/syntax/ALL.nanorc
Specify the ones you want to have colorizing for, and you will have to tune these colors to your preferences. The ALL.nanorc describes features for all yet unclassified files. These are the tools you need to get started, not the end polished product.
- 103
- 1,087
- 1
- 7
- 2
I used this command to quickly enable all available languages.
find /usr/share/nano/ -iname "*.nanorc" -exec echo include {} \; >> ~/.nanorc
As mentioned in other answers, /usr/share/nano/ contains the definitions for different languages.
asm.nanorc fortran.nanorc man-html ocaml.nanorc ruby.nanorc
awk.nanorc gentoo.nanorc man.nanorc patch.nanorc sh.nanorc
cmake.nanorc groff.nanorc mgp.nanorc perl.nanorc tcl.nanorc
c.nanorc html.nanorc mutt.nanorc php.nanorc tex.nanorc
Also mentioned, to enable highlighting for a language, you add include and the path to the language definition you want to enable to your ~/.nanorc file. So, for example, to enable C/C++ you would add this line.
include /usr/share/nano/c.nanorc
The find command searches for files or directories within the specified directory.
- The
-inameflag tells it to only look for files with a name that ends with.nanorc. - The
-execflags defines a command to execute on each file found. - The
{}gets replaced with the file name. \;is used to signify the end of the command to execute to thefindcommand.- Lastly,
>> ~/.nanorccauses the output to be appended to your~/.nanorcfile.
- 949
This should include all the syntax highlighting plugins included by default, and any you add to /usr/share/nano:
find /usr/share/nano -name '*.nanorc' -printf "include %p\n" > ~/.nanorc
Or, edit /etc/nanorc and see if you can uncomment the includes.
This works if you have a version of nano that refuses to accept wildcards in the .nanorc file.
Just run this line every time you add an additional .nanorc colour config.
- 205
You can use this to include all: (add this to ~/.nanorc file)
include "/usr/share/nano/*.nanorc"
Happy coding!
- 103
I accidentally disabled highlighting using the keyboard shortcut Alt+Y. It can be turned on again with the same keyboard shortcut.
- 4,947
I thought I might suggest something more fresh and up-to-date as of almost 2020 :
Scopatz's nanorc on Git has all you need. it is still regularly updated.
and is delivered with a pretty neat install guide & documented installer that allows you to get things rolling fast, clean, & easy.
Note : You might have to drop some of the highlighters from the nanorc file or comment them out (etc-host, html, and html.j2) as they seem to be faulty, but no big deal
- 207,228
- 141
I know it is an old thread but may my solution can help
edit the file at /etc/nanorc
From the line 243 you can find lot include files. Simply uncomment the ones you need, save and done.
## Nanorc files
include "/usr/share/nano/nanorc.nanorc"
## C/C++
include "/usr/share/nano/c.nanorc"
## Makefiles
include "/usr/share/nano/makefile.nanorc"
## Cascading Style Sheets
include "/usr/share/nano/css.nanorc"
## Debian files
include "/usr/share/nano/debian.nanorc"
## Gentoo files
# include "/usr/share/nano/gentoo.nanorc"
I am not sure if you update nano will these changes vanished.
Edit: outdated, please refer to other answers
The most complete and up to date syntax hilighters for nano are maintained here
To install all highlighters for your user just run:
cd /tmp
git clone https://github.com/tech4david/nano-highlight.git
cd nano-highlight/
make install
echo "include ~/.nano/syntax/ALL.nanorc" >> ~/.nanorc
- 123
For those who are having trouble after following the instructions above, also check if you have duplicate definitions. These will disable all syntax highlighting for all files. I ran into this after adding a nanorc.nanorc file, and not realising that my ~/.nanorc already had an identical section, i.e.:
## Here is an example for nanorc files.
syntax "nanorc" "\.?nanorc$"
## Possible errors and parameters
icolor brightwhite "^[[:space:]]*((un)?set|include|syntax|i?color).*$"
## Keywords
icolor brightgreen "^[[:space:]]*(set|unset)[[:space:]]+(autoindent|backup|$
icolor green "^[[:space:]]*(set|unset|include|syntax)\>"
- 133
nano ~/.nanorc
just write below code i
set linenumbers
- 11
- 1
To add support for TypeScript JSX (.tsx) files do the following:
- Open ~/.nanorc file and find "javascript" slug using ctrl+w in nano editor
- You should find something like
include /Users/youruser/nanorc/javascript.nanorc, open this .nanorc file - On the first line edit
syntax "JavaScript" "\.(js|ts)$"tosyntax "JavaScript" "\.(js|ts|jsx|tsx)$"to include .jsx and .tsx file extensions
- 111
For those who have working and included *.nanorc files but still see a monochrome text (or maybe regular and bold, use Alt+Y while editing to toggle syntax highlighting), it may be your TERM environment variable is not recognized. I had it set to xterm-256color but on that particular host that value didn't use color in nano for whatever reason.. doing $ TERM=screen worked for me.
You can see what it currently is with $ echo $TERM.
- 101
wget -r -nH --cut-dirs=3 --no-parent --reject="index.html*" https://nanosyntax.googlecode.com/svn/trunk/syntax-nanorc/ -P ~/.nano-syntax
for i in `ls --color=never -1 ~/.nano-syntax/*.nanorc` ; do echo "include $i" >> ~/.nanorc ; done
- 25
I found syntax highlighting for js here.
I appended it into my user file at ~/.nanorc
However to get a file into which I could append, I had to first copy from /usr/share/nano/nanorc.nanorc to my local folder first as ~/.nanorc.
- 92,125
- 101
