As per the advice in this question, I have attempted to use mkusb to make a persistent USB drive. However, it fails to do so (or any other function it has when pointed at that USB)
If it is relevant, I am running mkusb on Lubuntu an IBM T-42 Thinkpad with 1GB ram and an intel Centrio mobile processor (I had to force PAE on install). I am attempting to boot the liveUSB on a Dell Insperion all-in-one with Windows 8.
Console output of mkusb:
 mkusb-dus - Do USB Stuff
mkusb-dus needs superuser permissions (sudo) for some tasks, in order to prepare and write to the target, a block device.
 dus 12.0.7
live system or temporary superuser permissions
Drive that contains source file: /dev/sda
Live drive, that is booted from: /dev/sda
cands=2
  4K
  4K
built-in device
sdb
SanDisk_Ultra
28.7G
usb
USB or memory card
p_target: target=/dev/28.7G
No device or bad device
p_clean:
clean if necessary and return
 Press Enter to finish mkusb-dus
karel
  • 122,292
  • 133
  • 301
  • 332
J.Smith
  • 85
After a debugging dialogue, the bug was found and squashed. The problem was some confusing data due to a floppy drive (a bug that only affects very old computers) in the function p_list_drives in the program dus:
grep -v zram --> grep -v -e zram -e ^fd
A new version can be installed via the following commands
sudo add-apt-repository ppa:mkusb/unstable
sudo apt-get update
sudo apt-get dist-upgrade
The current update (2017-04-02) installs mkusb version 12.0.9
Edit: After further testing (2017-04-03) this version is uploaded to the stable PPA, ppa:mkusb/ppa and can be installed via the following 'standard' commands
sudo add-apt-repository ppa:mkusb/ppa
sudo apt-get update
sudodus
  • 47,684
