Here's the scenario: I would like to use a live USB to boot up my computer sometimes and access large programs that I want to run in Ubuntu only. However, I only have access to an 8gb USB drive, and the programs I'm looking at are around 50gb and upwards. From my research, I think I have to set up persistence, but instead of saving files to my USB, I want to be able to save files to my computer without messing up my current operating system and whatnot. How do I do that?
EDIT: If I mount my hard drive, is there anything I have to do to make my programs install there, and how can I do it so that my OS settings are stored on the USB (So I can take it with me), and my large programs are still on my OS.
EDIT: Errors with mkusb
Drive that contains source file: /dev/sda
Live drive, that is booted from: /dev/sda
cands=2
 50G
 50G
built-in device
sdb
SanDisk_Cruzer_Glide
 7.5G
usb
USB or memory card
p_target: target=/dev/ 7.5G
No target device or bad target device
p_clean:
ThunderBird
  • 1,963
  • 13
  • 22
  • 31
Led
  • 48
Persistent live with a casper-rw partition in the internal drive
  • You can create a persistent live drive with mkusb according to the following links,
    help.ubuntu.com/community/mkusb
    help.ubuntu.com/community/mkusb/persistent
  • Ubuntu will search for a file with the name casper-rw or a partition with the label casper-rw, and use the first one that it finds. So you can
    • remove or re-label the casper-rw partition on the USB pendrive (created by mkusb),
    • In Windows shrink the Windows partition (typically C:) and leave the freed drive space as 'unallocated'.
    • Boot live-only from the Ubuntu live drive, 'Try Ubuntu',
      • start gparted and
        • create a partition in the unallocated drive space and
        • in the partition create an ext4 file system
        • set the label casper-rw on this partition
    • Now, when you reboot the Ubuntu live drive, you should be able to boot persistent live and it will use the casper-rw partition in the internal drive. It should be possible to install your large programs and they are stored (automatically) in the casper-rw partition in the internal drive.
Test that it really works
As you can see in the screenshot, the casper-rw partition in the internal drive /dev/sda is 49 GiB, and it is used for persistence. The operating system is running from a [16 GB] USB pendrive /dev/sdb, where the automatically created casper-rw partition is re-labeled to casper-off.
sudodus
  • 47,684
You could probably mount the hard drive of the computer as it is.
To find what partitions you have on the system run
sudo fdisk -l
Then mount the apropriate partition
sudo mount /dev/device /mnt/mountpoint
You might need to specify type of the device. Use
-t type
where type can be ntfs or other file formats supported by your live USB.
ReineS
  • 46
