I am having an interesting issue. I upgraded my graphics cards and now the NVidia driver does not recognize it. As a result, when I attempt to boot into Ubuntu, I get spammed with an error stating that the driver has not recognized my card and then I get a black screen.
I have tried the follow:
  1. set nvidia.modeset=0 in GRUB options
  2. use nomodeset (following instructions here: Ubuntu 16.04 + Nvidia Driver = Blank screen)
  3. Boot into recovery mode and try "failsafe" graphics. This led to my BIOS screaming a loud beeping at me.
  4. Use the root command prompt from recovery mode. This doesn't work since when I mount the drive (so I have write access so I can modify files) it loads the driver and I get spammed with the error.
Any ideas? At this point I am about to call it quits and just re-install 16.04 from scratch.
It'sPete
  • 307
I got it to work!
Here's what I did:
  1. Booted into recovery mode with root cmd prompt.
  2. Mounted the drive with "mount --options remount,rw /"
  3. Purged the drivers with "sudo apt-get purge nvidia-*"
  4. At this point I was able to boot into Ubuntu, went to "Additional Drivers" and selected the latest available Nvidia driver.
  5. Even after install, the driver wasn't see my card. I had to go to tty1 (CTRL+ALT+F1) and run "sudo service lightdm restart". My screen flickered a few times and then came back up in my monitor's native resolution.
Hope this helps others who are stuck.
It'sPete
  • 307
