Brigtness in my dell xps 15 9550 is to high, when I lower it to minimum, it still is to high. I want to be able to lower the brightness even to 0.
I tried what is suggested in here:
Decrease Backlight Below Minimum
But when i execute the first command, i get the value of 1, and if i change to 0 the screen has no brightness at all. When i increse the brightness value, the minimum is still the one i had at first, and it is just to high.
pafm
  • 33
I couldn't find a way to make the brightness lower than the default minimum, but Desktop Dimmer is a reasonable workaround that I use on a regular basis. Running it will dim your screen however much you want. Desktop Dimmer is available in Ubuntu Software center.
