I'm fairly new to the Linux world and I'm setting up an Ubuntu server 16.04.
I was able to generate keys using ssh-keygen and saved the key in /home/ther4nd0moo/.ssh/id_rsa
I then used ssh-copy-id ther4nd0moo@my_ip and made sure that the authorized_keys file is in the right place.
When I use ssh -v ther4nd0moo@my_ip on a different computer, some weird things pop up (to me at least)
OpenSSH_7.2p2 Ubuntu-4ubuntu2.1, OpenSSL 1.0.2g 1 Mar 2016
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug1: Connecting to 10.0.0.189 [10.0.0.189] port 22.
debug1: Connection established.
debug1: key_load_public: No such file or directory
debug1: identity file /home/edgar/.ssh/id_rsa type -1
debug1: identity file /home/edgar/.ssh/id_rsa-cert type -1
debug1: identity file /home/edgar/.ssh/id_dsa type -1
debug1: identity file /home/edgar/.ssh/id_dsa-cert type -1
debug1: identity file /home/edgar/.ssh/id_ecdsa type -1
debug1: identity file /home/edgar/.ssh/id_ecdsa-cert type -1
debug1: identity file /home/edgar/.ssh/id_ed25519 type -1
debug1: identity file /home/edgar/.ssh/id_ed25519-cert type -1
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_7.2p2 Ubuntu-4ubuntu2.1
debug1: Remote protocol version 2.0, remote software version OpenSSH_7.2p2 Ubuntu-4ubuntu2.1
debug1: match: OpenSSH_7.2p2 Ubuntu-4ubuntu2.1 pat OpenSSH* compat 0x04000000
debug1: Authenticating to 10.0.0.189:22 as 'need206'
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: algorithm: curve25519-sha256@libssh.org
debug1: kex: host key algorithm: ecdsa-sha2-nistp256
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: Server host key: ecdsa-sha2-nistp256 SHA256:YzQwUoOherHwxOOhzEhue7ecx+OMi0FpmIcSONi8X1o
debug1: Host '10.0.0.189' is known and matches the ECDSA host key.
debug1: Found key in /home/edgar/.ssh/known_hosts:3
debug1: rekey after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_input_ext_info: server-sig-algs=<rsa-sha2-256,rsa-sha2-512>
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey
debug1: Next authentication method: publickey
debug1: Trying private key: /home/edgar/.ssh/id_rsa
debug1: Trying private key: /home/edgar/.ssh/id_dsa
debug1: Trying private key: /home/edgar/.ssh/id_ecdsa
debug1: Trying private key: /home/edgar/.ssh/id_ed25519
debug1: No more authentication methods to try.
Permission denied (publickey).
What's bugging me is how it's looking for the identity file and private key at /home/edgar/ (edgar being my name that I put in when installing the server). In an attempt to solve this, copied the key contents from /home/ther4nd0mmoo/.ssh and created the folder /home/edgar/.ssh which is probably why it has the message Found key in /home/edgar/.ssh/known_hosts:3 but I still can't access the server.
I tried ssh -i /home/ther4nd0moo/.ssh/id_rsa ther4nd0moo@my_ip and my terminal says that it is not accessible: No such file or directory
Am I doing something wrong?
